Home » Eclipse Projects » Equinox » Error with the org.eclipse.update.configurator
Error with the org.eclipse.update.configurator [message #87768] Tue, 08 May 2007 14:13
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I have a simple OSGi server. Here is the config.ini:
eclipse.ignoreApp=true
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start
org.osgi.service.http.port=8080
org.mortbay.log.LogFactory.noDiscovery=true
#DEBUG=true
# End of file marker - must be here
eof=eof
When I start the server with -consolelog I get the following error:
!ENTRY org.eclipse.update.configurator 2007-05-08 13:42:36.531
!MESSAGE C:\downloads\equinox\eclipse-33M7\plugins\plugins is not a
valid plugins directory.
I searched and found some posts that say this is supposed to go away if
you add the eclipse.ingoreApp=true
As you can see I have that what is causing the error to come up?
Is there a document that describes how the update.configurator works.
right now I'm editing my config.init to get the OSGi server to load and
start all of the plugins
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (Cygwin)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGQL3QyHA2ZZVyicQRAtpsAJwK408FeXtj4P0AnO/s7M1aHp2p0gCe JlMf
fYDwef3Ru9WwMwbgZ16S6Ms=
=Fss+
-----END PGP SIGNATURE-----
Previous Topic:Multiple ExtensionRegistries in OSGi
Next Topic:invoke osgi from a .bat/.sh file
Current Time: Fri Sep 19 13:41:59 EDT 2025
Powered by FUDForum. Page generated in 0.03434 seconds
