Custom widget - iframe focus? [message #87750] |
Thu, 15 May 2008 12:27  |
Originally posted by: mike.xmos.com
I have a custom text widget (essentially just a <textarea> inside an
iframe) and I need to set the focus on the iframe in order to update the
cursor position in the textarea. I can call textarea.focus() from my
javascript but I think the iframe itself needs to have focus for the
textarea element to update.
In other words I need to simulate a mouse click on the textarea - the
line only update works after I click inside the textarea!
Does anyone know how to achieve this?
Mike
Re: Custom widget - iframe focus? [message #88724 is a reply to message #88682] |
Tue, 20 May 2008 05:02   |
Originally posted by: rherrmann.innoopract.com
Hi Mike,
did you try to put the EditArea in a qooxdoo div (e.g.
CanvasLayout)? The gmaps example in the custom widget tutorial does
this. The tutorial can be found here:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. rap.help/help/html/advanced/custom-widget.html
The most recent version of this document is available in the tooling
download.
Rüdiger
Mike Wrighton wrote:
> Well I'm building a web-based IDE for C development. I'm using a
> third-party javascript source editor called EditArea - this is normally
> displayed within a webpage so the easiest (only?) way of using this as a
> widget seemed to be to put it in it's own qooxdoo iframe. I'm also using
> a Java applet to run client-side simulations, so I've had to use another
> iframe for that. I'm quite new to web development so I wasn't really
> aware of the issues in using iframes. Do you know of any alternatives?
> Thanks for your help.
> Mike
> Rüdiger Herrmann wrote:
>> Hi Mike,
>> I don't know of any way to simulate a mouse click. But you might be
>> better of asking the experts at qooxdoo (http://qooxdoo.org).
>> As I know of many implications when using an IFRAME, I would recommend
>> to not use this element if ever possible.
>> If that doesn't help, maybe you could explain in greater detail what
>> you want to achieve?
>> Cheers,
>> Rüdiger
>>> Hi,
>>> the cursor position in the textarea. I can call textarea.focus() from
>>> my javascript but I think the iframe itself needs to have focus for
>>> the textarea element to update.
>>> Thanks,
>>> Mike
Re: Custom widget - iframe focus? [message #89187 is a reply to message #88724] |
Wed, 21 May 2008 08:42   |
I haven't tried that, but since my javascript editor requires an html
textarea to do the syntax highlighting on, I assumed I would need an
iframe for the html?
> Hi Mike,
> did you try to put the EditArea in a qooxdoo div (e.g. CanvasLayout)?
> The gmaps example in the custom widget tutorial does this. The tutorial
> can be found here:
> download.
> Cheers,
> Rüdiger
>> normally displayed within a webpage so the easiest (only?) way of
>> using this as a widget seemed to be to put it in it's own qooxdoo
>> iframe. I'm also using a Java applet to run client-side simulations,
>> so I've had to use another iframe for that. I'm quite new to web
>> development so I wasn't really aware of the issues in using iframes.
>> Mike
>>> Hi Mike,
>>> recommend to not use this element if ever possible.
>>> Cheers,
>>> Rüdiger
>>>> Hi,
>>>> from my javascript but I think the iframe itself needs to have focus
>>>> for the textarea element to update.
>>>> the line only update works after I click inside the textarea!
>>>> Thanks,
>>>> Mike
Re: Custom widget - iframe focus? [message #89262 is a reply to message #89187] |
Wed, 21 May 2008 14:46  |
Mike,
as far as I know a this doesn't force you to use an ifame. But I am
not Javascript expert at all. You may just give it a try or ask on
the experts from the qooxdoo mailing-list.
Rüdiger
>> Hi Mike,
>> download.
>> Cheers,
>> Rüdiger
>>> Mike
>>>> Hi Mike,
>>>> Cheers,
>>>> Rüdiger
>>>>> Hi,
>>>>> an iframe) and I need to set the focus on the iframe in order to
>>>>> update the cursor position in the textarea. I can call
>>>>> textarea.focus() from my javascript but I think the iframe itself
>>>>> needs to have focus for the textarea element to update.
>>>>> Thanks,
>>>>> Mike
FUDForum. Page generated in 0.05524 seconds
