Home » Modeling » UML2 » UML Metamodel question
UML Metamodel question [message #874459] Sun, 20 May 2012 20:13 Go to next message
here is a line from xmi file
<packagedElement xmi:type="uml:Class" xmi:id="_iLYQsCGhEeG_6MYlNgu7vQ"
name="Board"/>
where is that uml:Class "defined"? in uml 2.x
specification?(http://www.omg.org/spec/UML/20080501/Infrastructure.xmi)
or is that UML2 specific?
there is a line in file UML.metamodel.uml in org.eclipse.uml2.uml.resources
<packagedElement xmi:type="uml:Class" xmi:id="Class" name="Class">
is that exactly the "definition" i look for?
(sorry for newbie question, i know it is also ugly formulated, but i'm
just trying to learn all that stuff)
Emil
Re: UML Metamodel question [message #874536 is a reply to message #874459] Mon, 21 May 2012 01:43 Go to previous messageGo to next message
Prior to UML 2.5, UML is defined as a merge of Infrastructure and
Superstructure, with at least three different recognised levels of
merge. In practice only the all-in merge is ever used. So to read the
specification you need to do the poorly specified merge in your head.
The MDT/UML2 merge is the de facto UML merge.
As an Eclipse user, you're probably most interested in UML.merged.uml or
UML.ecore.
UML 2.5 simplifies UML so that there is a single specification with
everything merged. It is a major improvement making substantial use of
model-driven generation; even the OCL has been tool checked. The draft
is going through its final polishing touches before going through the
OMG approval process. It's available now to OMG members, probably 6
months to a year before public view.
Ed Willink
On 21/05/2012 01:13, Emil Huseynli wrote:
> Hello,
> name="Board"/>
> Regards,
> Emil
Re: UML Metamodel question [message #874559 is a reply to message #874536] Mon, 21 May 2012 02:45 Go to previous messageGo to next message
Hi Ed,
your answer is valuable in sense of bringing new information about
structure of uml metamodel before and after 2.5 standard and filling
gaps of my knowledge in area, but i still didn't get answer to my two
questions :)
to summarize, i wanted to know where comes that "uml:Class" (and other
type idents, for example "uml:LiteralUnlimitedNatural") from? Where is
structure of xmi files created by UML2 controlled? Happens that in some
schema files?
Emil
On 21.05.2012 07:43, Ed Willink wrote:
> Hi
> UML.ecore.
> Regards
> Ed Willink
>> Hello,
>> name="Board"/>
>> Regards,
>> Emil
Re: UML Metamodel question [message #874566 is a reply to message #874559] Mon, 21 May 2012 02:54 Go to previous messageGo to next message
EMF uses Ecore files which are mostly superior to XSD; you gain
consistency and lose anarchic flexibility.
EMF can import or export XSD to rescue/avoid excluding misguided legacy
communities.
It does not make sense to talk of XML schema while using EMF; we use
metamodels.
"As an Eclipse user, you're probably most interested in UML.merged.uml
or UML.ecore."
Ed Willink
On 21/05/2012 07:45, Emil Huseynli wrote:
> Hi Ed,
> questions :)
> some schema files?
> Regards,
> Emil
>> Hi
>> UML.ecore.
>> Regards
>> Ed Willink
>>> Hello,
>>> name="Board"/>
>>> Regards,
>>> Emil
Re: UML Metamodel question [message #874571 is a reply to message #874566] Mon, 21 May 2012 03:09 Go to previous messageGo to next message
Found UML.ecore, it was in another jar file, not in
"org.eclipse.uml2.uml.resources_*.jar"
<eClassifiers xsi:type="ecore:EClass" name="Class"
eSuperTypes="#//EncapsulatedClassifier #//BehavioredClassifier">
but still don't see UML.merged.uml, is it available only in newest
versions of UML2?
On 21.05.2012 08:54, Ed Willink wrote:
> Hi
> communities.
> metamodels.
> or UML.ecore."
> Regards
> Ed Willink
>> Hi Ed,
>> questions :)
>> some schema files?
>> Regards,
>> Emil
>>> Hi
>>> UML.ecore.
>>> Regards
>>> Ed Willink
>>>> Hello,
>>>> name="Board"/>
>>>> Regards,
>>>> Emil
Re: UML Metamodel question [message #874624 is a reply to message #874571] Mon, 21 May 2012 05:12 Go to previous messageGo to next message
UML.merged.uml is in the same folder as UML.ecore, but you may have to
check UML2 out of CVS (Indigo) or GIT (Juno) since UML.merged.uml is not
distributed.
Ed Willink
> versions of UML2?
>> Hi
>> communities.
>> metamodels.
>> or UML.ecore."
>> Regards
>> Ed Willink
>>> Hi Ed,
>>> questions :)
>>> some schema files?
>>> Regards,
>>> Emil
>>>> Hi
>>>> UML.merged.uml or
>>>> UML.ecore.
>>>> Regards
>>>> Ed Willink
>>>>> Hello,
>>>>> name="Board"/>
>>>>> i'm
>>>>> Regards,
>>>>> Emil
Re: UML Metamodel question [message #874631 is a reply to message #874624] Mon, 21 May 2012 05:27 Go to previous messageGo to next message
Ok, thanks a lot!
> distributed.
Re: UML Metamodel question [message #877382 is a reply to message #874566] Sat, 26 May 2012 12:06 Go to previous messageGo to next message
what's the difference between UML.ecore and UML.metamodel.uml? They both
are xmi serializations of the UML metamodel, not?
Thanks in advance
> or UML.ecore."
Re: UML Metamodel question [message #877393 is a reply to message #877382] Sat, 26 May 2012 12:44 Go to previous messageGo to next message
Surely the file extension is self-explanatory? *.ecore, *.uml.
(They have different meta-models).
Ed Willink
On 26/05/2012 17:06, Emil Huseynli wrote:
> Hello,
> both are xmi serializations of the UML metamodel, not?
> Thanks in advance
>> or UML.ecore."
Re: UML Metamodel question [message #877403 is a reply to message #877393] Sat, 26 May 2012 13:18 Go to previous messageGo to next message
Ed, can you please explain purpose of both a bit more detailed? if you
have time of course :)
Re: UML Metamodel question [message #877420 is a reply to message #877403] Sat, 26 May 2012 13:41 Go to previous messageGo to next message
Sorry. Ed Merks and co have written an excellent book. I suggest you
read it. (The EMF book).
Ed Willink
Re: UML Metamodel question [message #877428 is a reply to message #877420] Sat, 26 May 2012 13:50 Go to previous messageGo to next message
can you at least give a suggestion on which chapter i should
concentrate? give some directions...
On 26.05.2012 19:41, Ed Willink wrote:
> Hi
> Regards
> Ed Willink
Re: UML Metamodel question [message #877434 is a reply to message #877428] Sat, 26 May 2012 14:08 Go to previous messageGo to next message
Given the variety of your questions, I recommend a quick skim to
familiarize yourself with the breadth of the contents and then read
what's most relevant.
Ed Willink
>> Hi
>> Regards
>> Ed Willink
Re: UML Metamodel question [message #877450 is a reply to message #877420] Sat, 26 May 2012 15:07 Go to previous messageGo to next message
ok, i'll try to find answers myself, but i would really appreciate if
someone else still tries to help...
> Hi
> Regards
> Ed Willink
Re: UML Metamodel question [message #877475 is a reply to message #877403] Sat, 26 May 2012 16:36 Go to previous messageGo to next message
Emil,
The UML.metamodel.uml model is the description, in UML, of UML itself. Its
main usefulness is for the definition of profiles. Profiles extending the
UML language reference this metamodel, and stereotypes in such a profile
define metaclass extensions targeting the classes in the UML metamodel.
UML supports definition of profiles extending other metamodels than UML.
For example, Ecore.uml describes the Ecore metamodel using UML. Profiles
referencing that metamodel can define Stereotypes that extend the
metaclasses of Ecore.
The UML.ecore is simply the Ecore description of the UML metamodel that the
EMF run-time needs to work with *.uml instances.
HTH,
Christian
Re: UML Metamodel question [message #877479 is a reply to message #877475] Sat, 26 May 2012 16:51 Go to previous messageGo to next message
thanks a lot for the info!
On 26.05.2012 22:36, Christian W. Damus wrote:
> Emil,
> HTH,
> Christian
Re: UML Metamodel question [message #877492 is a reply to message #877479] Sat, 26 May 2012 17:28 Go to previous message
No problem.
Note that my example of profiling Ecore wasn't the best, because of course,
it only works if Ecore is generated from UML, which provides API for
accessing applied stereotypes etc. Normally, Ecore is generated from
Ecore.ecore, and I wouldn't dream of doing it any other way.
I didn't intend to cause confusion.
Christian
>> Emil,
>> HTH,
>> Christian
Previous Topic:packageImport
Next Topic:UML2EcoreConverter, default values and EAttribute.unsettable
Current Time: Sat Jul 26 12:00:51 EDT 2025
Powered by FUDForum. Page generated in 0.08500 seconds
