Home » Language IDEs » Java Development Tools (JDT) » New (unexpected) warning with Juno 4.2 RC2
New (unexpected) warning with Juno 4.2 RC2 [message #877355] Sat, 26 May 2012 10:37 Go to next message
I have a Java 7 code, that compiles without any warnings with Eclipse Indigo 3.7.2.
When trying to move to Eclipse Juno 4.2RC2, I get a warning that I don't understand.
Here my code sample:
try (InputStreamReader socketIn = new InputStreamReader(fSocket.getInputStream())) {
   while (isConnected()) {
      int k = socketIn.read(charData);
} catch (IOException e) {
The warning is "Resource leak: socketIn is never closed"
(my understanding was that Java 7 will ensure that the resource will be closed outside the try / catch block.)
Installed JRE: Java 1.7_u4 (from Oracle, on a Win 7 PC).
Any idea ?
Bernard.
Re: New (unexpected) warning with Juno 4.2 RC2 [message #877369 is a reply to message #877355] Sat, 26 May 2012 11:14 Go to previous messageGo to next message
Hi Bernard,
This looks like a bug. Using just the lines you quoted doesn't seem to suffice for reproducing.
Could you please check the code you omitted and compare against existing bugs like:
- https://bugs.eclipse.org/bugs/show_bug.cgi?id=371614
- https://bugs.eclipse.org/bugs/show_bug.cgi?id=360910
If your code looks different please file a new bug with sufficient code for reproducing.
Stephan
Re: New (unexpected) warning with Juno 4.2 RC2 [message #877390 is a reply to message #877369] Sat, 26 May 2012 12:35 Go to previous messageGo to next message
Thanks for your quick reply.
I have the feeling that it is the same bug as bug_id=371614, but just in case, here is a full snippet that shows the warning:
The warning disappears if I remove the "while (true)" line.
package p;
import java.io.IOException;
import java.io.InputStreamReader;
import java.net.Socket;
public class myClass implements Runnable {
    private Socket fSocket;
    public synchronized void connect() throws IOException {
        fSocket = new Socket("localhost", 12345);
    public void run() {
            while (true) {
                if (socketIn.read(new char[1024]) < 0)
                    throw new IOException("Error");
Bernard.
Re: New (unexpected) warning with Juno 4.2 RC2 [message #877431 is a reply to message #877390] Sat, 26 May 2012 14:03 Go to previous message
Thanks for the example,
I can reproduce now and will follow up in bug 371614 (for 4.3, maybe 4.2.1).
Stephan
Previous Topic:Errors in setting up JSF in a dynamic web module.
Next Topic:creating new eclipse project using APIs getting error when using same workspace
Current Time: Sat Jul 26 18:22:39 EDT 2025
Powered by FUDForum. Page generated in 0.04172 seconds
