Home » Modeling » TMF (Xtext) » Stop refresh process for outline view if syntax errors are present
Stop refresh process for outline view if syntax errors are present [message #877329] Sat, 26 May 2012 09:17 Go to next message
Hey,
I'm saving pretty frequent even if my file contains syntax errors. The save process triggers the outline view to be updated. If the editor contains syntax errors, a pop-up windows shows the error:
index.php/fa/9926/0/
I was wondering if it is possible to stop the refresh process while the editor contains syntax errors? Thank you!
Kon
  • Attachment: error .png
    (Size: 19.36KB, Downloaded 430 times)
[Updated on: Sat, 26 May 2012 09:17] by Moderator
Re: Stop refresh process for outline view if syntax errors are present [message #878435 is a reply to message #877329] Tue, 29 May 2012 05:41 Go to previous messageGo to next message
Kon,
you'll find the stack trace in the error log. Please file a ticket with
that one attached.
Sebastian
Am 26.05.12 15:17, schrieb kon fri:
> Hey,
> I attached a screenshot. I was wondering if it is possible to stop the refresh process while the editor contains syntax errors? Thank you!
> Kon
Re: Stop refresh process for outline view if syntax errors are present [message #879490 is a reply to message #878435] Thu, 31 May 2012 06:00 Go to previous message
Hey Sebastian,
I created a ticket [1].
Thank you.
Kon
[1] bugs.eclipse.org/bugs/show_bug.cgi?id=381159
Previous Topic:naming and scopes
Next Topic: Auto insert single proposals
Current Time: Sat Jul 19 01:56:43 EDT 2025
Powered by FUDForum. Page generated in 0.46774 seconds
