Home » Eclipse Projects » Eclipse Scout » Scout and web-based GUIs
Scout and web-based GUIs [message #877126] Fri, 25 May 2012 19:19 Go to next message
I like Eclipse RCP and Equinox.
Is there a "Scout way" to build automatically an AJAX+HTML application from Eclipse RCP code ? Don't want to rewrite the whole code for a porting.
If yes can I download an example app anywhere ?
Thank you.
Re: Scout and web-based GUIs [message #877290 is a reply to message #877126] Sat, 26 May 2012 06:46 Go to previous messageGo to next message
A scout application consists of models for form, field, desktop, view, etc, including gui/business logic and glue code.
This model does not contain any swt, swing, ajax etc. code.
By adding the scout gui plugins (swt/rcp, swing, ajax,rap) this application becomes a RCP, AJAX, RAP application.
In short. The scout way of creating applications is by not creating a hard-wired swt,swing or ajax application in the first place.
Therefore for example a migration from an existing scout "Swing" application to a scout "Ajax" application is a zero step. Just changing the involved gui plugins.
This all describes the front-end part.
The back-end part is similar. It uses the equinox server side as the core for services (osgi), integration, jax-ws and j2ee (bridge servlet).
Re: Scout and web-based GUIs [message #878163 is a reply to message #877290] Mon, 28 May 2012 14:18 Go to previous messageGo to next message
Was this information helpful for you?
eclipse scout comes with a samle app and a complete tutorial to create/build/run in swing, swt rap.
Re: Scout and web-based GUIs [message #879049 is a reply to message #877126] Wed, 30 May 2012 08:42 Go to previous message
Hi Jean-Luc,
We don't have complete sample applications with RAP available yet. But this is something that should come in the future.
If you want to give it try, I suggest to follow the following tutorials:
(sorry for the incomplete URLs, I am not yet allowed to post URLs Sad)
Start creating a simple Scout application with this tutorial:
http//wiki.eclipse.org/Scout/Tutorial/3.8/HelloWorld
Then you can follow this tutorial to export your sample application to your own application servers:
http//wiki.eclipse.org/Scout/Tutorial/3.8/Deploy_to_Tomcat
To work through these tutorials you can e.g. use the developer build of Scout 3.8:
http//www.eclipse.org/downloads/index-developer.php
regards,
matthias
Previous Topic:Change layout in rap client
Next Topic:Scout/SDK/Designer View
Current Time: Tue Jul 22 23:59:35 EDT 2025
Powered by FUDForum. Page generated in 0.05036 seconds
