Home » Archived » Test and Performance Tools Platform (TPTP) » AGR like Web Application Testing
AGR like Web Application Testing [message #87704] Thu, 16 November 2006 13:04 Go to next message
Originally posted by: omkarashish.gmail.com
I am new to TPTP. I want to use TPTP to test a web interface. The HTTP
recorder with TPTP, as far as, I understand can be used only for
performance testing.
Essentially I want to be able to record a test case, use data pools to
provide variable test data and be able to use verification hooks. Is there
some way in which I can test web UI using TPTP.
If TPTP ddoes not have such a facility are there any plans of building a
web / java UI testing framework similar to AGR.
Any help would be greatly appreciated.
Thanks and regards,
- Ashish
Re: AGR like Web Application Testing [message #87869 is a reply to message #87704] Fri, 17 November 2006 16:24 Go to previous messageGo to next message
UI interaction with web-based applications is not possible with the HTTP
recorder. The recorder programmatically makes requests based on a recorded
session. I'm not aware of any plans to extend the HTTP recorder/AGR to
allow functional testing of web-based applications. There are commercial
offerings out there that allow you to do what you're looking for (e.g. IBM
Rational Functional Tester).
Thanks.
"Ashish Shinde" <omkarashish@gmail.com> wrote in message
news:1c63964f27e63408b3122d93d0c8603a$1@www.eclipse.org...
> Thanks and regards,
> - Ashish
Re: AGR like Web Application Testing [message #87949 is a reply to message #87869] Mon, 20 November 2006 01:16 Go to previous message
Thanks a ton Ali for the reply.
Previous Topic:No more handles during startup of AGR test on Linux
Next Topic:Launch error, return code from startProcess0() = -1 in JUnit tests using TPTP
Current Time: Sat Jul 26 08:00:07 EDT 2025
Powered by FUDForum. Page generated in 0.06166 seconds
