<<Allocate>> Stereotype between two SysML Ports [message #877037] |
Fri, 25 May 2012 15:02  |
I would like to express an allocate relationship between the port of a block and another port of another block. To this end I have thought to stereotype a dependency relationship between the two ports.
However the <<Allocate>> stereotype does not appear among those applicable (<<allocated>> is in the applicable list but it is not the right one). I have read <<Allocate>> can be applied to UML::Abstractions and I have read in the UML Superstructure it is a kind of dependency used to this kind of semantics. As Abstraction is less generic than Dependency I can't apply <<allocate>> to Dependency, I understand it. But I can't see neither how to istantiate an Abstraction object in the model nor how to depict the <<allocate>> edge in the editor palette. It appears if I create a class diagram but it does not in SysML Block Diagrams.
FUDForum. Page generated in 0.04178 seconds
