Home » Archived » BIRT » BIRT with Multiple Data sets(BIRT with Multiple Data sets)
BIRT with Multiple Data sets [message #876768] Fri, 25 May 2012 04:59 Go to next message
How do BIRT report work with multiple data sets?
Suppose I create a report with multiple data set say- Employee, Department and Location all present in a single data source and I am not using Joined data set. Will BIRT automatically link all the 3 data sets once the data is processed and available to BIRT? How are multiple data source handeled(linked) in BIRT? How will BIRT use the data from multiple data sets? Do the data sets remain disjoined?
Re: BIRT with Multiple Data sets [message #876931 is a reply to message #876768] Fri, 25 May 2012 10:23 Go to previous message
The only way data sets are joined is in a joint data set or a birt data
cube. In both of those cases you decide how they are joined. Other
than those cases birt does not join any datasets, but you can nest
datasets like in nested tables.
Jason
Previous Topic:ReferenceError: "BarSeriesImpl" is not defined. at line X of chart script:''
Next Topic:How can I pass a parameter to my report?
Current Time: Fri Jul 25 19:50:02 EDT 2025
Powered by FUDForum. Page generated in 0.05186 seconds
