Home » Modeling » TMF (Xtext) » [Xtend 2.3 M6] Function1 cannot be used as parameter
[Xtend 2.3 M6] Function1 cannot be used as parameter [message #876731] Fri, 25 May 2012 03:56 Go to next message
Hi there,
I'm currently playing around with Xtend2 and it seems to be a very cool and innovative project. In order to replace the old
EXPAND function FOREACH sampleList
construct from Xpand I would like to build a similar syntax with Xtend2.
For now the only way to do it is to call
sampleList.map([function]).join
which is annoying me. I wonder why there isn't an extension for such often used constructs (or am I doing it the wrong way?). I would have expected an extension for lists in that case, but it doesn't seem to be there.
I have tried to simplify the map-join syntax. Here is my first approach (it is not compiling!):
import org.eclipse.emf.common.util.EList
import org.eclipse.xtext.xbase.lib.Functions.Function1
def <T> String toString(EList<T> value, Function1<T, CharSequence> func)
  return value.map(func).join
The whole thing crashes because it seems to be impossible to import Function1 and use it as parameter. Anyone has an idea why this is the case?
I tried another solution but it didn't work either because the code is generated in a way, that doesn't work with my solution:
import org.eclipse.xtext.xbase.lib.internal.FunctionDelegate
import com.google.common.collect.Lists
def <T> String toString(EList<T> value, FunctionDelegate<T, CharSequence> func)
  return Lists::transform(value, func).join;
Nevertheless with a helper class it is easy to add a workaround, but I wonder why I need to do it in plain java. For all who are interested in: here is the code of the helper class and an Xtend2 example how it can be used in a way that fits my needs (thanks to the "it" feature of Xtend2 ;)):
import java.util.List;
import org.eclipse.emf.common.util.EList;
import org.eclipse.xtext.xbase.lib.IterableExtensions;
import org.eclipse.xtext.xbase.lib.ListExtensions;
import org.eclipse.xtext.xbase.lib.Functions.Function1;
public class Helper {
  public static <T> String toString(EList<T> value, Function1<T, CharSequence> func)
    List<Object> _map = ListExtensions.<T, Object>map(value, func);
    String _join = IterableExtensions.join(_map);
    return _join;
def private printExample(ParentType parent)
  «allChilds.toString([generateChildContent])»
def private generateChildContent(ChildType it)
  // this method doesn't make much sense, but who cares ;)
  return name
Well, maybe the next release M8 of Xtend2 extends the existing ListExtensions class with such a toString or output method.
[Updated on: Fri, 25 May 2012 04:06] by Moderator
Re: Xtend2: Generic dispatch method does not compile [message #876738 is a reply to message #876731] Fri, 25 May 2012 04:06 Go to previous messageGo to next message
Hi you Import nested classes with Outer$Inner
Re: Xtend2: Generic dispatch method does not compile [message #876752 is a reply to message #876738] Fri, 25 May 2012 04:33 Go to previous messageGo to next message
Thanks Christian, so that's not supported in Xtend2? Any reasons why that's possible in java but not supported in Xtend2?
Re: Xtend2: Generic dispatch method does not compile [message #876764 is a reply to message #876752] Fri, 25 May 2012 04:51 Go to previous messageGo to next message
As Christian said, use
import org.eclipse.xtext.xbase.lib.Functions$Function1
or the more xtend-y syntax
	def static <T> String toString(EList<T> value, (T)=>CharSequence func)
Re: Xtend2: Generic dispatch method does not compile [message #876767 is a reply to message #876752] Fri, 25 May 2012 04:56 Go to previous messageGo to next message
Hi, i do net get your point
package org.xtext.example.mydsl
class Helper {
	def <T> String toString(EList<T> value, Functions$Function1<T, CharSequence> func)
	def <T> String toString2(EList<T> value, (T) => CharSequence func)
~Christian
Re: Xtend2: Generic dispatch method does not compile [message #876840 is a reply to message #876767] Fri, 25 May 2012 07:15 Go to previous message
Thanks guys, I've misunderstood Christians comment. I haven't found any documentation about the importing of inner classes. Everything works fine now.
Previous Topic:importURI strange problems
Next Topic:Cross-Reference
Current Time: Thu Jul 24 22:51:01 EDT 2025
Powered by FUDForum. Page generated in 0.27148 seconds
