Home » Modeling » EMF » Strategies for handling dangling references?
Strategies for handling dangling references? [message #875390] Tue, 22 May 2012 12:44 Go to next message
So I have an ecore model and some custom editors to edit the instances. A dilemma we've run into relates to dangling references, specifically references to contained objects that are then removed from their container. For example, if I have a model like this:
EmailAddress
Person (contains an EmailAddress)
Message (references an EmailAddress)
Assume I have a Person, joe, and a Message that refers to joe's EmailAddress. If I edit joe and delete his EmailAddress, the Message will have a dangling reference. Which means that the Message can no longer be edited and saved - the save will fail because it can't resolve the reference to joe's EmailAddress.
So we're looking for strategies to solve this in a real-world application. There are lots of reasons to want to mark an error on the Message but still allow the user to load, edit, and save it. I'm curious about how other people have solved this problem in a user-friendly way.
One idea we've been tossing around is to re-parent deleted contained objects into a "tombstone" container, so that the references to them are still valid. I can see a couple of potential problems with that approach, such as what URI does the "tombstone" container use so that there is enough information about the original container to be useful in error markers, quick-fix, etc. Following the above example model, this idea would mean that when joe's email address is deleted, it would be placed in a "dummy" Person (joe_tombstone) so that the Message's reference is still valid as far as EMF is concerned. We'd have to build some custom mechanism to find and handle those during our build, too.
Any thoughts on that idea (such as, "warning: there be dragons")? Or any other ideas?
Eric
Re: Strategies for handling dangling references? [message #875427 is a reply to message #875390] Tue, 22 May 2012 14:29 Go to previous messageGo to next message
Eric,
Comments below.
> EmailAddress
There are these options:
String OPTION_PROCESS_DANGLING_HREF = "PROCESS_DANGLING_HREF";
String OPTION_PROCESS_DANGLING_HREF_THROW = "THROW";
String OPTION_PROCESS_DANGLING_HREF_DISCARD = "DISCARD";
String OPTION_PROCESS_DANGLING_HREF_RECORD = "RECORD";
> user-friendly way.
It's pretty easy to find all the dangling reference and remove them.
EcoreUtil.UnresolvedProxyCrossReferencer is handy...
Is the problem more one of saving (the options are good for that) or of
loading (there will be broken proxies)?
How much information is in the broken proxy? Clever use of fragment
paths that include names of the things along the path could be helpful...
> any other ideas?
> Eric
Re: Strategies for handling dangling references? [message #876510 is a reply to message #875427] Thu, 24 May 2012 14:41 Go to previous messageGo to next message
Ed Merks wrote on Tue, 22 May 2012 14:29
Eric,
Comments below.
> EmailAddress
In my tests, using the DISCARD or RECORD options result in the save succeeding but the reference being set to null. That's not desirable in our application, because it amounts to changing something the user did not expect.
> user-friendly way.
We can't just remove them, for various reasons. It's just not a user-friendly thing to do (at least in our application). The user needs to be able to load, edit, and save a model that has one of these dangling references, without losing the reference entirely when he saves.
The problem, for now at least, is saving. We want the user to be able to save models that have a reference to a an orphaned fragment, but not lose the information about that reference (essentially, its URI). That's because we want users to be able to edit other parts of the model while the orphaned reference is present.
I'm not understanding you. The reference URI does have useful information, including the original container(s) of the fragment, true.
What do you think of the "tombstone" idea? Do you see any major hurdles or pitfalls down that path?
Better yet, do you have any other recommendations for how to address our basic need (re-stated above, hopefully more clearly)?
Eric
Re: Strategies for handling dangling references? [message #876538 is a reply to message #876510] Thu, 24 May 2012 16:04 Go to previous messageGo to next message
Eric,
Comments below.
>> Eric,
>> Comments below.
>> > So I have an ecore model and some custom editors to edit the >
>> instances. A dilemma we've run into relates to dangling references, >
>> specifically references to contained objects that are then removed >
>> > EmailAddress
>> > Assume I have a Person, joe, and a Message that refers to joe's >
>> > longer be edited and saved - the save will fail because it can't >
> did not expect.
> Quote:
>> > So we're looking for strategies to solve this in a real-world >
>> the > Message but still allow the user to load, edit, and save it.
>> I'm > curious about how other people have solved this problem in a >
>> user-friendly way.
You could convert them into proxies, so they're saved with whatever
proxy URI you set. Upon loading, you'll have an unresolved proxy with
that URI again...
> Quote:
>> contained > objects into a "tombstone" container, so that the
>> references to them > are still valid. I can see a couple of potential
>> problems with that > approach, such as what URI does the "tombstone"
>> container use so that > there is enough information about the
>> original container to be useful > in error markers, quick-fix, etc.
>> of loading (there will be broken proxies)?
It has no URI once it's removed from its container. Perhaps you set a
proxy URI to it while you remove it from the container...
They'll fix it at some point?
> Quote:
>> > Following the above example model, this idea would mean that when >
>> Person > (joe_tombstone) so that the Message's reference is still
>> valid as far > as EMF is concerned. We'd have to build some custom
>> mechanism to find > and handle those during our build, too.
>> helpful...
Once resolved, you only have the object, and once it's orphaned you have
no information for how it should be relocated or what it's URI should be
upon saving...
It's okay, but not so different from setting a proxy URI and saving it
that way.
No, but do they ever get deleted or cleaned up.
Setting a proxy URI would be okay. Not sure what it should be...
> Eric
Re: Strategies for handling dangling references? [message #896014 is a reply to message #876538] Mon, 16 July 2012 18:38 Go to previous messageGo to next message
Revisiting an old topic, now that we've implemented part of a solution. More below, at the end...
Ed Merks wrote on Thu, 24 May 2012 16:04
Eric,
Comments below.
>> Eric,
>> Comments below.
>> > EmailAddress
>> user-friendly way.
that URI again...
> Quote:
The strategy we've taken is to find all external references and set a proxy URI on them. It seems to work, except for one important wrinkle. Our editors use the EMF Edit framework, so all model edits are happening via Commands. If the user removes the contained object (EmailAddress) in the editor, the references are found and proxy-fied. Unfortunately, that includes the original object that was removed. So if the user invokes Undo, the Command puts the original back into its container, but that instance is now a proxy. Worse part is, I can't seem to re-resolve it now. I've tried ECoreUtil.resolve() but it fails to find the object; it's already back in it's container but is still a proxy.
Any ideas how I can either
A) prevent the original instance from being proxified; I don't think this is possible because of instance caching the instance that is found when searching for external references is the same as the one that is removed from the container.
B) Re-resolve the proxy instance during or after Undo
Thanks again,
Eric
Re: Strategies for handling dangling references? [message #896054 is a reply to message #896014] Tue, 17 July 2012 01:40 Go to previous messageGo to next message
Eric,
Comments below.
>> Eric,
>> Comments below.
>> >> Eric,
>> >> Comments below.
>> references, > >> specifically references to contained objects that
>> are then removed > >> from their container. For example, if I have a
>> model like this:
>> >> > EmailAddress
>> Message >> > will have a dangling reference. Which means that the
>> Message can no >> > longer be edited and saved - the save will fail
>> because it can't > >> resolve the reference to joe's EmailAddress.
>> > >> user-friendly way.
>> > We can't just remove them, for various reasons. It's just not a >
>> user-friendly thing to do (at least in our application). The user >
>> these > dangling references, without losing the reference entirely
>> when he saves.
>> with that URI again...
>> > Quote:
>> able > to save models that have a reference to a an orphaned
>> fragment, but > not lose the information about that reference
>> a proxy URI to it while you remove it from the container...
> proxy.
It would just resolve to itself. The proxification should be done as a
command and of course that should implement undo to unproxify it.
No, I think you need to proxify it. Otherwise you need to swizzle all a
references, and of course then you'd have an even bigger undo problem.
I think only the proxy URI needs to be set back to null again...
> Thanks again,
> Eric
Re: Strategies for handling dangling references? [message #896531 is a reply to message #896054] Wed, 18 July 2012 13:28 Go to previous message
Ed Merks wrote on Tue, 17 July 2012 01:40
Eric,
Comments below.
> proxy.
Before, I wasn't including the proxification as part of the edit command (I was doing it manually after Command execution); now I've implemented a custom Command that can do it (and undo as well) and use a CompoundCommand to execute it after the RemoveCommand. Seems to work quite well.
You're right, just setting the proxy URI back to null un-does the proxification nicely. I've only done smoke testing, but so far it appears to be a good solution.
Eric
Previous Topic:New child menu entry for EMap and custom dialog
Next Topic:[xcore] problem referencing UML classes?
Current Time: Fri Jul 25 11:14:34 EDT 2025
Powered by FUDForum. Page generated in 0.25707 seconds
