Home » Modeling » TMF (Xtext) » importURI strange problems(importURI, quotes)
icon9.gif  importURI strange problems [message #876435] Thu, 24 May 2012 11:35 Go to next message
Hey.
I have long time with this and not understand the error ...
This works:
Grammar:
grammar pruebas.MyDsl
ScxmlStateType  hidden(WS):
	'<state'
		( 'id=' name = ID
		& ('src=' importURI = LocalUrl)?
		& ('initial=' initial1 = [ScxmlStateType | ID])? ) //state
	scxmlStateMix = ScxmlStateMix
ScxmlStateMix:
		( state += ScxmlStateType*
		& transition += ScxmlTransitionType* )
	'</state>')
ScxmlTransitionType:
	{ScxmlTransitionType}
	'<transition'
		 ('target=' target = [ScxmlStateType | ID])? // state
LocalUrl:
	('../')? ID (('/' | '../') ID )* ('.' ID)?
LocalUrlDataType:
 	QUOTE_V1 LocalUrl QUOTE_V1
 	//| QUOTE_V2 LocalUrl QUOTE_V2
terminal QUOTE_V1:
terminal QUOTE_V2:
terminal ID:
	('a'..'z'|'A'..'Z'|'_'|'-') ('a'..'z'|'A'..'Z'|'_'|'-'|'0'..'9')*
terminal WS:
	(' '|'\t'|'\r'|'\n')+
I can reference states in another files which indicated by state src attribute...
x.test
<state id=x1 [b]src=y.test[/b]>
	<state id=x2>
		<transition target=y2 />
	</state>
</state>
y.test
<state	id=y1>
	<state id=y2>
		<transition target=y1 />
	</state>
</state>
But if instead of
Put's
'src=' importURI = LocalUrlDataType
That is, the same thing with quotes. It does not work. And I do not understand why.
Someone can help me?
Thank you.
A greeting.
[Updated on: Thu, 24 May 2012 11:36] by Moderator
Re: importURI strange problems [message #876490 is a reply to message #876435] Thu, 24 May 2012 13:57 Go to previous messageGo to next message
Hi did you provide a value converter rule for the quoted URL as Xtext
does for strings?
Re: importURI strange problems [message #876829 is a reply to message #876490] Fri, 25 May 2012 06:52 Go to previous message
THANKS!
I have a few time with XText and I don´t known I had to do this ...
This is my solution, for if it could be useful to someone in the future. I was inspired by solution provided by pettergraff blog.
MyDslRuntimeModule
public class MyDslRuntimeModule extends pruebas.AbstractMyDslRuntimeModule {
    public Class<? extends IValueConverterService> bindIValueConverterService() {
        return LocalUrlDataTypeValueConverter.class;
public class LocalUrlDataTypeValueConverter extends DefaultTerminalConverters {
    @ValueConverter(rule = "LocalUrlDataType")
    public IValueConverter<String> LocalUrlDataType() {
        return new IValueConverter<String>() {
            public String toValue(String string, INode node) {
        		if (string == null)
        			return null;
        		try {
        			return Strings.convertFromJavaString(string.substring(1, string.length() - 1), true);
        		} catch (IllegalArgumentException e) {
        			throw new ValueConverterException(e.getMessage(), node, e);
            public String toString(String value) {
                return value;
Thank you very much.
a greeting
Previous Topic:Type Checking with JvmTypeParameter and JvmArgumentTypeReference
Next Topic:[Xtend 2.3 M6] Function1 cannot be used as parameter
Current Time: Sat Jul 26 14:16:06 EDT 2025
Powered by FUDForum. Page generated in 0.07730 seconds
