Home » Eclipse Projects » Eclipse 4 » Change 'locale' attribute in TranslationService at Runtime
Change 'locale' attribute in TranslationService at Runtime [message #876286] Thu, 24 May 2012 06:08 Go to next message
There is an attribute
@Inject
	@Named(LOCALE)
	protected String locale;
in the org.eclipse.e4.core.services.translation.TranslationService class which is used in the translate-implementation of org.eclipse.e4.core.internal.services.BundleTranslationProvider to get the ResourceBundle for the given locale.
I thought that the injection-logic will update the locale-attribute when I do the following:
m_Application.getContext().set(TranslationService.LOCALE, "de");
but nothing happens (breakpoint in translate showed that the value of locale was still 'en' -> the locale.getdefault)
Am I missing smth?
Marko
Re: Change 'locale' attribute in TranslationService at Runtime [message #876331 is a reply to message #876286] Thu, 24 May 2012 07:42 Go to previous messageGo to next message
The TranslationService is currently created on the Root-Context which is
the parent of the context attached to MApplication.
The problem is that the important code parts (most import ones are the
Renderers) are not reacting on the change of a locale so dynamic switch
the UI won't work as you'd expect it to work ;-)
We only had time to create the foundation for future in implementations.
Tom
Am 24.05.12 12:08, schrieb Marko Herchet:
> There is an attribute @Inject
> @Named(LOCALE)
> I do the following:
> Am I missing smth?
> Marko
Re: Change 'locale' attribute in TranslationService at Runtime [message #876362 is a reply to message #876331] Thu, 24 May 2012 09:02 Go to previous messageGo to next message
Thanks for the answer Tom.
I replaced my code with
m_Application.getContext().getParent().set(TranslationService.LOCALE, "de");
and it works the way I want.
the UI won't work as you'd expect it to work Wink
I think I understand what you mean, but at the time I want to change the locale, the workbench is empty except for MainWindow, MainMenu and the MainToolbar. So it will be no problem as long as there is a way for me to tell the renderers that they have to update/recreate the said 3 elements. Think I've seen smth like MenuManagerRenderer.clean(MUIElement) but I'm not sure if this is what iam looking for.
Some suggests how to archieve this?
Marko
[Updated on: Thu, 24 May 2012 09:03] by Moderator
Re: Change 'locale' attribute in TranslationService at Runtime [message #876445 is a reply to message #876362] Thu, 24 May 2012 11:52 Go to previous messageGo to next message
If you use a lifecycle-handler you can get in even earlier (before any
rendering has happened!).
I don't think there's currently a way to instruct the renderers to
reread informations beside setting a new value on the label which will
lead to a model event the renderer is registered on.
Tom
Am 24.05.12 15:02, schrieb Marko Herchet:
> "de");
> Quote:
>> the UI won't work as you'd expect it to work ;)
> to tell the renderer that he has to update/recreate the said 3 elements.
> Marko
Re: Change 'locale' attribute in TranslationService at Runtime [message #877399 is a reply to message #876286] Sat, 26 May 2012 13:09 Go to previous message
What I found out, is that some Texts will change automatically after running my code. Tooltips of MainToolbarItems for example seems to be updated on every enablement check. Don't know if this is by design. Labels of Submenus will occur in the right language too, when opened (even if it was opened before the language-change). But iam not sure if the submenu-items are newly created on every menuShow like I usually do it in ContextMenus for my Trees and Tables.
For the other Widgets are not too many, I will just iterate over them after language change and manually change their labels to smth. like MMenuElement.getTranslatedLabel(). Already tried it and it seems to work.
Thanks for your help Tom
Previous Topic:API to programmatically modify product configuration
Next Topic:What happens to the class HandlerUtil
Current Time: Tue Jul 22 22:22:53 EDT 2025
Powered by FUDForum. Page generated in 0.05631 seconds
