Home » Modeling » TMF (Xtext) » XText TextViewer instead of Editor
| XText TextViewer instead of Editor [message #875558] |
Tue, 22 May 2012 20:40  |
Have created a simple query language to use with a BIRT ODA driver.
Instead of using the XText generated Editor for my query language, I
will need to present the user with a TextViewer in the DataSet Wizard in
order to specify the query string.
I am still a novice when it comes to XText, but I did look but haven't
found any documentation, examples or newsgroup entries regarding a use
case like this.
Can anyone give me an example on how to go about doing this.
thanks,
John
| Re: XText TextViewer instead of Editor [message #875939 is a reply to message #875558] |
Wed, 23 May 2012 11:32   |
John,
if you use Xtext 2.3, you may want to have a look at the
EmbeddedEditorFactory.
Sebastian
Am 23.05.12 02:40, schrieb John E. Conlon:
> case like this.
> thanks,
> John
| Re: XText TextViewer instead of Editor [message #876548 is a reply to message #876268] |
Thu, 24 May 2012 16:25   |
Hi Vlad,
I'd try something along these lines:
public class MultiPageEditor extends MultiPageEditorPart {
@Inject
private Provider<XtextEditor> editorProvider;
private XtextEditor editor;
protected void createPages() {
try {
editor = editorProvider.get();
int index = addPage(editor, getEditorInput());
setPageText(index, editor.getTitle());
} catch (PartInitException e) {
ErrorDialog.openError(
getSite().getShell(),
"Error creating nested text editor",
null,
e.getStatus());
public void doSave(IProgressMonitor monitor) {
editor.doSave(monitor);
public void doSaveAs() {
editor.doSaveAs();
setPageText(0, editor.getTitle());
setInput(editor.getEditorInput());
public boolean isSaveAsAllowed() {
return true;
The EmbeddedEditorFActory should be used to embed an editor in a
composite that is not an IEditorPart itself.
Sebastian
Am 24.05.12 11:23, schrieb Vlad Dumitrescu:
> Sebastian Zarnekow wrote on Wed, 23 May 2012 17:32
>> John,
> Hi Sebastian,
> Would that be the recommended way to use a Xtext editor in a multi-page
> one too?
> regards,
> Vlad
| Re: XText TextViewer instead of Editor [message #1729519 is a reply to message #1729516] |
Fri, 15 April 2016 00:04   |
Hi Christian,
Thank you for your reply, I am using the code from sirius+Xtext integration on github. I just changed the code a little bit to run with double click on the object rather than a java extension.
So, if you just take a look at the createXtextEditor() method, there is segment for creating EmbeddedEditor. I just removed this EmbeddedEditor and added my code for SttyledTextXtextAdapter. So, the xtextresource is created based on the semantic element that I pass to this class. It is Weird because it works fine for the EmbeddedEditor and shows the text for the semantic element, but when I use StyledXtextAdapter it doesn't work and gives me empty text editor as if resource is totally empty! I can use content assistant and coloring is working but I guess the resource is just not set !
BTW, can I use StyledXtextCellEditor instead of StyledXtextAdapter ? They are pretty much the same, right ?
Thanks a lot,
Best Regards,
Parsa
* Copyright (c) 2011 Obeo and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Obeo - initial API and implementation
package org.obeonetwork.dsl.viewpoint.xtext.support;
import java.io.ByteArrayOutputStream;
import java.io.IOException;
import java.util.Collections;
import org.eclipse.draw2d.IFigure;
import org.eclipse.draw2d.geometry.Rectangle;
import org.eclipse.emf.common.util.BasicMonitor;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.compare.Comparison;
import org.eclipse.emf.compare.EMFCompare;
import org.eclipse.emf.compare.merge.BatchMerger;
import org.eclipse.emf.compare.merge.IBatchMerger;
import org.eclipse.emf.compare.merge.IMerger;
import org.eclipse.emf.compare.rcp.EMFCompareRCPPlugin;
import org.eclipse.emf.compare.scope.DefaultComparisonScope;
import org.eclipse.emf.compare.scope.IComparisonScope;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.emf.transaction.RecordingCommand;
import org.eclipse.emf.transaction.TransactionalEditingDomain;
import org.eclipse.emf.transaction.util.TransactionUtil;
import org.eclipse.gef.EditPartViewer;
import org.eclipse.gmf.runtime.diagram.ui.editparts.DiagramRootEditPart;
import org.eclipse.gmf.runtime.diagram.ui.editparts.IGraphicalEditPart;
import org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditDomain;
import org.eclipse.gmf.runtime.diagram.ui.parts.IDiagramEditDomain;
import org.eclipse.jface.text.BadLocationException;
import org.eclipse.sirius.viewpoint.DSemanticDecorator;
import org.eclipse.sirius.viewpoint.ViewpointPackage;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.StyledText;
import org.eclipse.swt.custom.VerifyKeyListener;
import org.eclipse.swt.events.KeyAdapter;
import org.eclipse.swt.events.KeyEvent;
import org.eclipse.swt.events.VerifyEvent;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.graphics.FontData;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Decorations;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IEditorPart;
import org.eclipse.xtext.nodemodel.ICompositeNode;
import org.eclipse.xtext.nodemodel.util.NodeModelUtils;
import org.eclipse.xtext.parser.IParseResult;
import org.eclipse.xtext.resource.IResourceFactory;
import org.eclipse.xtext.resource.XtextResource;
import org.eclipse.xtext.resource.XtextResourceSet;
import org.eclipse.xtext.ui.editor.XtextSourceViewer;
import org.eclipse.xtext.ui.editor.embedded.EmbeddedEditor;
import org.eclipse.xtext.ui.editor.embedded.EmbeddedEditorFactory;
import org.eclipse.xtext.ui.editor.embedded.EmbeddedEditorModelAccess;
import org.eclipse.xtext.ui.editor.embedded.IEditedResourceProvider;
import org.eclipse.xtext.ui.editor.info.ResourceWorkingCopyFileEditorInput;
import org.eclipse.xtext.ui.editor.model.IXtextDocument;
import org.eclipse.xtext.util.concurrent.IUnitOfWork;
import com.google.inject.Injector;
/* largely inspired by "org.eclipse.xtext.gmf.glue" from XText examples */
public class XtextEmbeddedEditor {
private static int MIN_EDITOR_WIDTH = 100;
private static int MIN_EDITOR_HEIGHT = 20;
private IGraphicalEditPart hostEditPart;
private IEditorPart diagramEditor;
private EmbeddedEditorModelAccess xtextPartialEditor;
private final Injector xtextInjector;
private Resource originalResource;
private XtextResource xtextResource;
private String semanticElementFragment;
private Decorations xtextEditorComposite;
private EmbeddedEditor xTextEmbeddedEditor;
public XtextEmbeddedEditor(IGraphicalEditPart editPart,
Injector xtextInjector) {
this.hostEditPart = editPart;
this.xtextInjector = xtextInjector;
protected EObject resolveSemanticElement(IGraphicalEditPart hostEditPart) {
EObject eObject = hostEditPart.resolveSemanticElement();
if (isDSemanticDecorator(eObject)) {
DSemanticDecorator semanticDecorator = (DSemanticDecorator) eObject;
return semanticDecorator.getTarget();
return resolveSemanticElement(hostEditPart);
private boolean isDSemanticDecorator(EObject eObject) {
return ViewpointPackage.eINSTANCE.getDSemanticDecorator().isInstance(
eObject);
public void showEditor() {
try {
EObject originalSemanticElement = resolveSemanticElement(hostEditPart);
if (originalSemanticElement == null) {
return;
this.originalResource = originalSemanticElement.eResource();
// Clone root EObject
EObject semanticElement = EcoreUtil.copy(originalResource
.getContents().get(0));
if (this.xtextResource == null) {
this.xtextResource = createVirtualXtextResource(
originalResource.getURI(), semanticElement);
// TODO manage multi resource with Xtext Linking or Scoping service
semanticElementFragment = originalResource
.getURIFragment(originalSemanticElement);
if (semanticElementFragment == null
|| "".equals(semanticElementFragment)) {
return;
IDiagramEditDomain diagramEditDomain = hostEditPart
.getDiagramEditDomain();
diagramEditor = ((DiagramEditDomain) diagramEditDomain)
.getEditorPart();
createXtextEditor();
} catch (Exception e) {
Activator.logError(e);
} finally {
if (hostEditPart != null) {
hostEditPart.refresh();
* Close this editor.
* @param isReconcile
public void closeEditor(boolean isReconcile) {
if (xtextPartialEditor != null) {
if (isReconcile) {
try {
updateXtextResource();
} catch (Exception exc) {
Activator.logError(exc);
// xtextEditor.dispose();
if (xtextEditorComposite != null) {
this.xtextEditorComposite.dispose();
xtextEditorComposite = null;
xtextPartialEditor = null;
private XtextResource createVirtualXtextResource(URI uri,
EObject semanticElement) throws IOException {
IResourceFactory resourceFactory = xtextInjector
.getInstance(IResourceFactory.class);
// TODO use the synthetic scheme.
XtextResourceSet rs = xtextInjector.getInstance(XtextResourceSet.class);
rs.setClasspathURIContext(getClass());
// Create virtual resource
XtextResource xtextVirtualResource = (XtextResource) resourceFactory
.createResource(URI.createURI(uri.toString()));
rs.getResources().add(xtextVirtualResource);
// Populate virtual resource with the given semantic element to edit
xtextVirtualResource.getContents().add(semanticElement);
// Save and reparse in order to initialize virtual Xtext resource
ByteArrayOutputStream out = new ByteArrayOutputStream();
xtextVirtualResource.save(out, Collections.emptyMap());
xtextVirtualResource.reparse(new String(out.toByteArray()));
return xtextVirtualResource;
protected void updateXtextResource() throws IOException,
BadLocationException {
String newText = xtextPartialEditor.getSerializedModel();
xtextResource.reparse(newText);
EcoreUtil.resolveAll(xtextResource);
final IParseResult parseResult = xtextResource.getParseResult();
if (!parseResult.hasSyntaxErrors() && !hasDanglingRefs(xtextResource)) {
reconcile(originalResource, xtextResource);
private boolean hasDanglingRefs(XtextResource xtextResource2) {
return EcoreUtil.UnresolvedProxyCrossReferencer.find(xtextResource2)
.size() > 0;
private void reconcile(Resource resourceInSirius,
XtextResource resourceInEmbeddedEditor) {
try {
IComparisonScope scope = new DefaultComparisonScope(
resourceInSirius, resourceInEmbeddedEditor, null);
final Comparison comparison = EMFCompare.builder().build()
.compare(scope);
IMerger.Registry mergerRegistry = EMFCompareRCPPlugin.getDefault()
.getMergerRegistry();
final IBatchMerger merger = new BatchMerger(mergerRegistry);
final TransactionalEditingDomain editingDomain = TransactionUtil
.getEditingDomain(originalResource);
editingDomain.getCommandStack().execute(
new RecordingCommand(editingDomain,
"update resource after direct text edit") {
protected void doExecute() {
merger.copyAllRightToLeft(
comparison.getDifferences(),
new BasicMonitor());
* Create the XText editor
* @param editorInput
* the editor input
* @throws Exception
protected void createXtextEditor() throws Exception {
DiagramRootEditPart diagramEditPart = (DiagramRootEditPart) hostEditPart
.getRoot();
Composite parentComposite = (Composite) diagramEditPart.getViewer()
.getControl();
EObject semanticElementInDocument = xtextResource
.getEObject(semanticElementFragment);
ICompositeNode rootNode = xtextResource.getParseResult().getRootNode();
String allText = rootNode.getText();
ICompositeNode elementNode = NodeModelUtils
.findActualNodeFor(semanticElementInDocument);
String prefix = allText.substring(0, elementNode.getOffset() - 1);
String editablePart = allText.substring(elementNode.getOffset(),
elementNode.getEndOffset());
String suffix = allText.substring(elementNode.getEndOffset());
xtextEditorComposite = new Decorations(parentComposite, SWT.RESIZE
| SWT.ON_TOP | SWT.BORDER);
xtextEditorComposite.setLayout(new FillLayout());
/* I remove this part:
EmbeddedEditorFactory factory = new EmbeddedEditorFactory();
xtextInjector.injectMembers(factory);
xTextEmbeddedEditor = factory.newEditor(new IEditedResourceProvider() {
public XtextResource createResource() {
return xtextResource;
}).showErrorAndWarningAnnotations().withParent(xtextEditorComposite);
xtextPartialEditor = xTextEmbeddedEditor.createPartialEditor(prefix,
editablePart, suffix, true);
// Add this part instead
IXtextFakeContextResourcesProvider contextProvider=new IXtextFakeContextResourcesProvider() {
public void populateFakeResourceSet(ResourceSet fakeResourceSet, XtextResource fakeResource) {
fakeResource=xtextResource;
fakeResourceSet=xtextResource.getResourceSet();
StyledTextXtextAdapter xTextAdaptor = new StyledTextXtextAdapter(xtextInjector,contextProvider);
xTextAdaptor.adapt(shellContainer.styledText);
addKeyVerifyListener();
setEditorBounds();
xtextEditorComposite.setVisible(true);
xtextEditorComposite.forceFocus();
private void addKeyVerifyListener() {
final StyledText xtextTextWidget = xTextEmbeddedEditor.getViewer()
.getTextWidget();
xtextTextWidget.addVerifyKeyListener(new VerifyKeyListener() {
public void verifyKey(VerifyEvent e) {
int keyCode = e.keyCode;
if ((e.stateMask & SWT.CTRL) != 0
&& ((keyCode == SWT.KEYPAD_CR) || (keyCode == SWT.CR))) {
e.doit = false;
closeEditor(true);
if (keyCode == SWT.ESC) {
e.doit = false;
closeEditor(false);
private void setEditorBounds() {
// mind the added newlines
String editString = xtextPartialEditor.getEditablePart();
int numLines = StringUtil.getNumLines(editString);
int numColumns = StringUtil.getMaxColumns(editString);
IFigure figure = hostEditPart.getFigure();
Rectangle bounds = figure.getBounds().getCopy();
.getRoot();
IFigure contentPane = diagramEditPart.getContentPane();
contentPane.translateToAbsolute(bounds);
EditPartViewer viewer = hostEditPart.getViewer();
Control control = viewer.getControl();
while (control != null && false == control instanceof Shell) {
bounds.translate(control.getBounds().x, control.getBounds().y);
control = control.getParent();
Font font = figure.getFont();
FontData fontData = font.getFontData()[0];
int fontHeightInPixel = fontData.getHeight();
int width = Math.max(fontHeightInPixel * (numColumns + 3),
MIN_EDITOR_WIDTH);
int height = Math.max(fontHeightInPixel * (numLines + 4),
MIN_EDITOR_HEIGHT);
xtextEditorComposite.setBounds(bounds.x - 200, bounds.y - 120, width,
height);
width + 250, height + 50);
[Updated on: Fri, 15 April 2016 00:06] by Moderator
| Re: XText TextViewer instead of Editor [message #1729649 is a reply to message #1729522] |
Sat, 16 April 2016 19:34   |
Hi again Christian,
I found that the StyledXtextAdapter shows the full text of my DSL file perfectly. However, when I pass the offset and length of my node to the setVisibleRegion(), it throws the following error. And, I am sure that the length of file is OK and the offset exists. I tried to trace the code and found that when I pass the setVisibleRegion(1752,9) , it turns out to become (3503,-1752) somewhere inside and have no idea why ! I though you might have some idea !
Bests,
Parsa
java.lang.IllegalArgumentException: Invalid visible region argument
at org.eclipse.jface.text.TextViewer.setVisibleRegion(TextViewer.java:3678)
at org.eclipse.jface.text.source.projection.ProjectionViewer.setVisibleRegion(ProjectionViewer.java:703)
at org.yakindu.base.xtext.utils.jface.viewers.StyledTextXtextAdapter.setVisibleRegion(StyledTextXtextAdapter.java:269)
at com.uwaterloo.cs.forml.viewpoint.xtext.support.AbstractXtextEmbeddedEditor.createPartControl(AbstractXtextEmbeddedEditor.java:499)
at com.uwaterloo.cs.forml.viewpoint.xtext.support.AbstractXtextEmbeddedEditor.createXtextEditor(Unknown Source)
at com.uwaterloo.cs.forml.viewpoint.xtext.support.AbstractXtextEmbeddedEditor.showEditor(Unknown Source)
at com.uwaterloo.cs.forml.viewpoint.xtext.support.XtextEmbeddedEditorForGuard.showEditor(XtextEmbeddedEditorForGuard.java:106)
at com.uwaterloo.cs.forml.viewpoint.xtext.support.CreateEmbeddedEditors$1.run(CreateEmbeddedEditors.java:107)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:186)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4761)
at com.uwaterloo.cs.forml.viewpoint.xtext.support.CreateEmbeddedEditors.runFormViewTransitionEditor(CreateEmbeddedEditors.java:70)
at com.uwaterloo.cs.forml.viewpoint.xtext.support.action.OpenXtextEmbeddedEditor.execute(OpenXtextEmbeddedEditor.java:70)
at org.eclipse.sirius.business.internal.helper.task.operations.ExternalJavaActionTask.execute(ExternalJavaActionTask.java:93)
at org.eclipse.sirius.business.internal.helper.task.ExecuteToolOperationTask.executeTask(ExecuteToolOperationTask.java:106)
at org.eclipse.sirius.business.internal.helper.task.ExecuteToolOperationTask.executeTask(ExecuteToolOperationTask.java:117)
at org.eclipse.sirius.business.internal.helper.task.ExecuteToolOperationTask.execute(ExecuteToolOperationTask.java:90)
at org.eclipse.sirius.business.api.helper.task.TaskExecutor.execute(TaskExecutor.java:64)
at org.eclipse.sirius.tools.api.command.SiriusCommand.doExecute(SiriusCommand.java:80)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.sirius.diagram.ui.tools.api.command.GMFCommandWrapper.doExecuteWithResult(GMFCommandWrapper.java:102)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.sirius.diagram.ui.tools.internal.commands.WrappingCommandIgnoringAffectedFiles.execute(WrappingCommandIgnoringAffectedFiles.java:124)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:516)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:71)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:52)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:156)
at org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditPart.performRequest(ConnectionEditPart.java:1476)
at org.eclipse.sirius.diagram.ui.edit.api.part.AbstractDiagramEdgeEditPart.performRequest(AbstractDiagramEdgeEditPart.java:703)
at org.eclipse.gef.tools.SelectEditPartTracker.performOpen(SelectEditPartTracker.java:194)
at org.eclipse.gef.tools.SelectEditPartTracker.handleDoubleClick(SelectEditPartTracker.java:137)
at org.eclipse.gef.tools.AbstractTool.mouseDoubleClick(AbstractTool.java:1069)
at org.eclipse.gef.tools.SelectionTool.mouseDoubleClick(SelectionTool.java:527)
at org.eclipse.gef.EditDomain.mouseDoubleClick(EditDomain.java:231)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouseDoubleClicked(DomainEventDispatcher.java:291)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDoubleClick(LightweightSystem.java:518)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:196)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
| Re: XText TextViewer instead of Editor [message #1729730 is a reply to message #1729654] |
Mon, 18 April 2016 10:51   |
Hi Christian,
Not sure what you mean by styledtextex, but I am using StyledText. my code is below. I found that this is related to the bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=352847
The bug is saying that offset = master.getLineOffset(line); should be changed to offset += master.getLineOffset(line); and in my case, I guess the it is the other way around !
public void createPartControl(Composite parent, EObject elem) {
IXtextFakeContextResourcesProvider fake = new
fakeResource.getContents().clear();
fakeResource.getContents().add(EcoreUtil.getRootContainer(elem));
try {
fakeResource.save(out,
SaveOptions.newBuilder().format().getOptions().toOptionsMap());
fakeResource.reparse(new String(out.toByteArray(), Charsets.UTF_8));
} catch (IOException e) {
e.printStackTrace();
StyledTextXtextAdapter adapter=new StyledTextXtextAdapter(xtextInjector, fake);
StyledText styledText = new StyledText(parent,SWT.WRAP );
adapter.adapt(styledText);
ICompositeNode node = NodeModelUtils.findActualNodeFor((adapter.getFakeResourceContext().getFakeResource().getEObject(semanticElementFragment)));
String s =node.getText();
styledText.setText(new String(out.toByteArray(), Charsets.UTF_8));
adapter.setVisibleRegion((node.getOffset(), node.getLength()));
and this is the code for XtextSourceViewer visible region:
* Overwritten to handle offset properly.
protected boolean updateSlaveDocument(IDocument slaveDocument,
int modelRangeOffset, int modelRangeLength)
throws BadLocationException {
if (slaveDocument instanceof ProjectionDocument) {
ProjectionDocument projection = (ProjectionDocument) slaveDocument;
int offset = modelRangeOffset;
int length = modelRangeLength;
if (!isProjectionMode()) {
// mimic original TextViewer behavior
IDocument master = projection.getMasterDocument();
int line = master.getLineOfOffset(modelRangeOffset);
length = (modelRangeOffset - offset) + modelRangeLength;
try {
// fHandleProjectionChanges= false;
setPrivateHandleProjectionChangesField(false);
projection.replaceMasterDocumentRanges(offset, length);
} finally {
// fHandleProjectionChanges= true;
setPrivateHandleProjectionChangesField(true);
return true;
return false;
Just thought it might be useful to know !
Bests,
Parsa
[Updated on: Mon, 18 April 2016 11:04] by Moderator
Current Time: Tue Nov 04 23:32:02 EST 2025
Powered by FUDForum. Page generated in 0.07133 seconds
