Home » Modeling » Papyrus » Customising Papyrus appearance
icon5.gif  Customising Papyrus appearance [message #876061] Wed, 23 May 2012 16:36 Go to next message
Hello all,
is it possible to customise the appearance of Papyrus. For example the stand alone version shows classes with a yellow background by default but the plug-in version does not. It is a little bit annoying to change the appearance of an element each time you paste it into a diagram.
I am currently using Papyrus 0.8.2. Each time I add an operation to a class and specify the arguments I need to change label customisation. Is there a way to set default appearance settings?
Konstantin
Re: Customising Papyrus appearance [message #876228 is a reply to message #876061] Thu, 24 May 2012 03:33 Go to previous messageGo to next message
Hello Konstantin,
You can use the Papyrus preferences to specify the default appearance options for your elements.
Window -> Preferences -> Papyrus -> Diagrams
Camille
Re: Customising Papyrus appearance [message #876526 is a reply to message #876228] Thu, 24 May 2012 15:22 Go to previous messageGo to next message
Hello Camille,
many thanks for the tip. This way I can influence the default settings for the appearance of classes etc. But the following questions remain open.
  1. I could not find any global settings for the appearance of operation parameters. I would like to enable the name of a parameter and disable the modifiers.
  2. Further I could not figure out how to apply the global settings to existing diagrams. As soon as I add a new class to my diagram the global appearance applies to the new class, but the existing classes in the diagram do not get updated. Is there a simple way to change this?
  3. Is there a way to export these settings to import them into another workspace?
Konstantin
Re: Customising Papyrus appearance [message #878356 is a reply to message #876526] Tue, 29 May 2012 02:23 Go to previous messageGo to next message
Hello Konstantin,
You need to go a little deeper in the Diagram preferences, to find the "Operation" item :
Diagrams > PapyrusUMLClassDiagram Diagram > Operation
There, you can customize the default label display (Visibility, Name, Parameter Direction, Modifiers and Parameter Type)
This is currently not possible. However, in Papyrus 0.9 (Which will be released in a few weeks, with Eclipse Juno), there is a support for CSS Stylesheets, which is more powerful than the current preferences-based customization.
Eclipse allows you to export your workspace preferences. Use "Export -> General -> Preferences", then choose "Export all" (Papyrus doesn't provide a specific category here...)
Camille
Re: Customising Papyrus appearance [message #878876 is a reply to message #878356] Wed, 30 May 2012 01:39 Go to previous message
Hello Camille,
That sounds good. Many thanks!
Konstantin
Previous Topic:Papyrus and manipulation
Next Topic:C++ Code Generation With Papyrus
Current Time: Fri Jul 25 11:12:04 EDT 2025
Powered by FUDForum. Page generated in 0.06084 seconds
