Problem Install eTrice Nightly Build [message #875250] |
Tue, 22 May 2012 08:10  |
I'd like to install the Nightly Build version of eTrice, because i've heard it supports C.
Unfortunately i am not able to install this version of eTrice, i've tried the following:
Eclipse->Help->Install New Software->Add and then i added the URL from the download page: http: //download.eclipse.org/etrice/updates/nightly
But that didn't work.
(I've downloaded the zip-archive too, but it has the same error message)
So is there a way to use this version ?
Thanks in advance,regards
Bernhard
P.S.: I've uploaded the Eclipse Install Error Message below.
Re: Problem Install eTrice Nightly Build [message #876722 is a reply to message #875250] |
Fri, 25 May 2012 03:36  |
Hi Bernhard,
if you read the complete error message (the bottom lines were not contained in your screen shot, see attached one) you are told that Xtext 2.1.1 could not be resolved by the update manager.
To solve this issue you have to add the composite Xtext releases update site
http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/
to your list of available sites.
You should also add
http://download.eclipse.org/graphiti/updates/0.8.2
Starting with a fresh Eclipse Modeling Tools package (Indigo 3.7.2, Windows 32bit) from
http://eclipse.org/downloads/
it worked for me.
Hope that helps,
Henrik
Bernhard Goesswein wrote on Tue, 22 May 2012 08:10Hi,
Bernhard
FUDForum. Page generated in 0.03549 seconds
