Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EcoreTools] Problem installing on 3.8
[EcoreTools] Problem installing on 3.8 [message #876015] Wed, 23 May 2012 14:38 Go to next message
I'm trying to install EcoreTools through the Juno update site on my Juno
(build Id: I20120125-1800) eclipse environment.
I don't get any errors and don't see anything related in the log, but
after I see the EcoreTools (1.1.0.201205041226) in the list of installed
software, but there are no contributed Ecore Features and only 1 plugin
for Ecore Tools documentation.
I've uninstall and re-installed, I also tried moving from Java 1.7 to
1.6, no luck.
And it's hard to give anyone more to help as I'm not getting any issue
during the install.
Help please.
Alain
Re: [EcoreTools] Problem installing on 3.8 [message #877007 is a reply to message #876015] Fri, 25 May 2012 13:32 Go to previous messageGo to next message
Alain,
The RC1 version of the Juno repo (just available today) seems to be in
better shape. I was able to install Ecore Tools into 4.2... Hopefully
it works for 3.8 too.
> Juno (build Id: I20120125-1800) eclipse environment.
> installed software, but there are no contributed Ecore Features and
> only 1 plugin for Ecore Tools documentation.
> 1.6, no luck.
> during the install.
> Help please.
> Thanks
> Alain
Re: [EcoreTools] Problem installing on 3.8 [message #877026 is a reply to message #876015] Fri, 25 May 2012 14:33 Go to previous messageGo to next message
Hi Alain,
There was a bug in the EcoreTools SDK feature.xml that caused the runtime feature to be no longer included. Cedric has
fixed that the other week.
Cheers
/Eike
http://www.esc-net.de
Am 23.05.2012 20:38, schrieb Alain Picard:
> I'm trying to install EcoreTools through the Juno update site on my Juno (build Id: I20120125-1800) eclipse environment.
> I don't get any errors and don't see anything related in the log, but after I see the EcoreTools (1.1.0.201205041226)
> in the list of installed software, but there are no contributed Ecore Features and only 1 plugin for Ecore Tools
> documentation.
> I've uninstall and re-installed, I also tried moving from Java 1.7 to 1.6, no luck.
> And it's hard to give anyone more to help as I'm not getting any issue during the install.
> Help please.
> Thanks
> Alain
Re: [EcoreTools] Problem installing on 3.8 [message #877146 is a reply to message #877026] Fri, 25 May 2012 20:32 Go to previous messageGo to next message
Thanks guys.
Alain
Re: [EcoreTools] Problem installing on 3.8 [message #878132 is a reply to message #877026] Mon, 28 May 2012 12:18 Go to previous message
Finally got around to upgrade and it worked.
Thanks again
Alain
Previous Topic:[Texo] ignore not null syntax
Next Topic:EMFInterceptor
Current Time: Wed Jul 23 14:54:17 EDT 2025
Powered by FUDForum. Page generated in 0.05193 seconds
