Higher-order model transformations with QVTo [message #875306] |
Tue, 22 May 2012 09:52  |
Does anyone know if it is possible to create a transformation which has a qvto-file as input and a qvto-file as output? I found this www.eclipse.org/forums/index.php/m/555659/ , but the transformation which is mentioned there only works if the output file is a xmi-file.
I know that in ATL it is possible to create higher-order transformations, is something like that also possible in QVTo?
Kind regards,
Maarten
Re: Higher-order model transformations with QVTo [message #988318 is a reply to message #987810] |
Thu, 29 November 2012 06:45  |
Comment added on the bug.
Bugs only really need assigning when there is a large pool of committers
fighting for the opportunity to fix a bug; sadly not the case with QVTo.
Ed Willink
On 28/11/2012 09:13, Gilbert Mirenque wrote:
> did something happen in this concerns? The bug report 377320 reported by
> Uwe Ritzman has nobody assigned. I'm very interested in doing
> higher-order transformations with a QVTO transformation as output, as well.
> best regards,
> Gilbert
FUDForum. Page generated in 0.46909 seconds
