Home » Eclipse Projects » Eclipse Platform » [data binding] how to make a binding be optional?
[data binding] how to make a binding be optional? [message #875686] Wed, 23 May 2012 03:17 Go to next message
Hi, I created a data binding between a SWT control and a Bean property,
assume there's a control named 'textAge' and a Bean class Person has a
field named 'age' whose type is int.
Now I bind them, binding framework first get value from textAge control,
it will get a empty string if user didn't input anything because
attribute 'age' is not required. But framework don't think so, it still
invoke converter to transform value between control and model. It
eventually called Integer.parseInt(value) and throwed a Exception
java.lang.NumberFormatException: For input string: ""
what I want is If framework found an EMPTY (null or length=0) string, it
give a waring and don't process further.
How to do? thank for your great help!!
Re: [data binding] how to make a binding be optional? [message #875698 is a reply to message #875686] Wed, 23 May 2012 03:41 Go to previous messageGo to next message
The first sync should always go from model to control. Can you show us
how you've set up the binding? My current suspicion is that you mixed
mixed the arguments.
You could naturally also add your custom converter by using passing an
UpdateStrategy object when doing the bind.
Tom
Am 23.05.12 09:17, schrieb David BY Chan:
Re: [data binding] how to make a binding be optional? [message #875726 is a reply to message #875698] Wed, 23 May 2012 04:30 Go to previous messageGo to next message
No, I did not mix the arguments. Here's my example:
EMF Model:
public interface GeneralStatement{
Integer getTimeout();
void setTimeout(Integer value);
Binding:
IObservableValue ob_txt_timeout =
SWTObservables.observeText(textTimeout,SWT.Modify);
IObservableValue ob_model_timeout = EMFObservables.observeValue(stmt,
stmt.eClass().getEStructuralFeature(Mapperv2Package.GENERAL_STATEMENT__TIMEOUT));
timeoutBinding = current_binding_context.bindValue(ob_txt_timeout,
ob_model_timeout);
I didn't use any converter because framework defined internal
StringToInteger conveter.
Exception:
at
java.lang.NumberFormatException.forInputString(NumberFormatException.java:48)
at java.lang.Integer.parseInt(Integer.java:470)
at java.lang.Integer.valueOf(Integer.java:554)
at
org.eclipse.emf.ecore.impl.EcoreFactoryImpl.createEIntegerObjectFromString(EcoreFactoryImpl.java:519)
I debugged the code, the first sync is from model to control, right! New
created GeneralStatement contains a field 'timeout' with null as its
value, internal ObjectToString converter converted null to "", so text
control display a blank, but the second round is from control to model,
framework found the target type is Integer, and try to convert "" to int
via Integer.parseInt(String).
> Tom
Re: [data binding] how to make a binding be optional? [message #875740 is a reply to message #875726] Wed, 23 May 2012 04:59 Go to previous message
The only solution I have for you at the moment is that you pass your
custom converter to the UpdateStrategy which handles the empty string
case and converts it to NULL.
The default conversion leverages EMFs internal conversion support which
works the way it works at the moment. You can naturally file a bugzilla
for EMF-Databinding to treat the "" case but I can't promise if and when
I'll have time to implement it.
Tom
Am 23.05.12 10:30, schrieb David BY Chan:
> EMF Model:
> Binding:
> timeoutBinding =
> current_binding_context.bindValue(ob_txt_timeout, ob_model_timeout);
> Exception:
> at
> at
>> Tom
Previous Topic:how to show tooltip description off-line(without the internet) in eclipse
Next Topic:View with secondary ID is not placed properly
Current Time: Wed Jul 23 13:19:50 EDT 2025
Powered by FUDForum. Page generated in 0.25060 seconds
