Home » Language IDEs » C / C++ IDE (CDT) » CDT for 3.0M5 ?
Re: CDT for 3.0M5 ? [message #87330 is a reply to message #86593] |
Mon, 24 November 2003 17:10   |
Right from the cdt-dev mailingslist:
> If I hear no word, I will commit my patch at 1 p.m. EST. From that point
> on, the CDT HEAD will only build against Eclipse 3.0. The commit covers
> almost every CDT project (format for plugin.xml changed slightly and
> turning on PDE containers plus changes for Eclipse 3.0). The CVS log will
> noisy.
> Doug Schaefer, Senior Software Developer
> IBM Rational Software, Ottawa, Ontario, Canada
> Douglas Schaefer/Ottawa/IBM@IBMCA
> Sent by: cdt-dev-admin@eclipse.org
> 11/24/2003 11:09 AM
> Please respond to
> cdt-dev
> The deed is done. Happy Eclipse 3.0'ing.
> I will be producing a CDT 2.0 build with these changes by the end of the
> day. This build will be the candidate build for our first CDT 2.0
> milestone and should be tested accordingly.
> Cheers,
> "Alain Magloire" <alain@qnx.com>
> 11/24/2003 11:50 AM
Does that sound good for you?
Timothee Besset schrieb:
> The update site for CDT
> http://update.eclipse.org/tools/cdt/updates/builds/2.0 says the packages
> are not compatible with M5 (they worked against M4). I suppose this is an
> expected situation .. when should we expect CDT builds for M5?
> TTimo
Re: CDT for 3.0M5 ? [message #87376 is a reply to message #87330] |
Tue, 25 November 2003 11:02   |
Weeeeeeee!
Which means next automated build will work again with M5 then. I guess I
should subscribe to the MLs sometime.
TTimo
On Mon, 24 Nov 2003 23:10:46 +0100
> > noisy.
> > 11/24/2003 11:09 AM
> > Please respond to
> > cdt-dev
> > Cheers,
> > 11/24/2003 11:50 AM
> > TTimo
Re: CDT for 3.0M5 ? [message #87555 is a reply to message #87376] |
Thu, 27 November 2003 17:24   |
Originally posted by: dschaefe.ca.ibm.com
No need to subscribe to the mailing list, we should be making these
announcements here for you folks as well.
CDT 2.0 M5 is now available and runs with Eclipse 3.0 M5. An official
announcement will follow shortly.
Doug
Timothee Besset wrote:
> Weeeeeeee!
> TTimo
>> > point on, the CDT HEAD will only build against Eclipse 3.0. The commit
>> > covers almost every CDT project (format for plugin.xml changed slightly
>> > and turning on PDE containers plus changes for Eclipse 3.0). The CVS
>> > log will noisy.
>> > 11/24/2003 11:09 AM
>> > Please respond to
>> > cdt-dev
>> > the day. This build will be the candidate build for our first CDT 2.0
>> > Cheers,
>> > 11/24/2003 11:50 AM
>> > packages are not compatible with M5 (they worked against M4). I suppose
>> > this is an expected situation .. when should we expect CDT builds for
>> > M5?
>> > TTimo
Re: CDT for 3.0M5 ? [message #88267 is a reply to message #88252] |
Mon, 01 December 2003 09:32   |
> Huh?
> I've been trying so hard to get this 2.0M5 to work with my new shiny
> eclipse 3.0M5 without any sucess. I dropped that into my eclipse,
> restarted, and nothing happens. No error, nothing. And eclipse
> does not show the new plugins either.
> I really love my shiny Eclipse M5, especially on Linux. But the
> two most needed tools do not work: GEF and CDT. Bugger...
> Could anyone give a hint on how to make this work?
> OS: Mandrake Linux 9.2
> Java: Sun JDK 1.4.2
> Eclipse: 3.0M5 (tried a couple of nightlies without any success)
> GEF : 2.1.2 (also tried some nightlies, no luck either)
Did you read the requirements on the GEF site? It states Eclipse 3.0M4(!),
NOT 3.0M5!
> CDT : 2.0M5 (no luck, with a combination of Eclipse nightlies)
CDT should work, when you change one minor bug one of the fragment.xml files.
I posted this already on the newsgroup and in bugzilla, so go for it.
> Thanks for any help. I want this shiny Eclipse M5, it's much
> nicer on Linux.
> kk
Re: CDT for 3.0M5 ? [message #91481 is a reply to message #88252] |
Mon, 12 January 2004 10:51  |
> Java: Sun JDK 1.4.2
> nicer on Linux.
Did you download the proper build for 3.0M5? On
http://www.eclipse.org/cdt/ click download. Then, on the middle of the
page, you see a table with different builds. Choose the following:
CDT 2.0 M5 for Linux/GTK2 -- R3.0 M5 -- 2.0 M5 - Linux (GTK2)
That worked without problems for me.
When plugins are not found, it is sometimes a permissions problem. Make
sure the user can read and access all plugin directories:
In the eclipse/ directory, type
chmod -R u+rx plugins
Current Time: Thu Jul 24 23:10:51 EDT 2025
Powered by FUDForum. Page generated in 0.30362 seconds
