Home » Modeling » TMF (Xtext) » [Xtext 2.3] Using the new debugging features
[Xtext 2.3] Using the new debugging features [message #870258] Mon, 07 May 2012 09:29 Go to next message
I wanted to try the new debugging features you get with Xtext 2.3 and
Xbase, thus I wrote the JvmModelInferrence for my test DSL with some
Operation which should correspond to Java methods. However, the
correspondence between an Operation and the Java method is not direct
(e.g., like in the Domainmodel example); for instance I do (I'll try to
simplify)
@Inject extension JvmTypesBuilder
@Inject extension IQualifiedNameProvider
@Inject extension TypeReferences
@Inject extension TypeReferenceSerializer
@Inject XbaseCompiler xbaseCompiler
def dispatch void infer(Greeting element, IJvmDeclaredTypeAcceptor
acceptor, boolean isPreIndexingPhase) {
acceptor.accept(
element.toClass( element.fullyQualifiedName )
).initializeLater [
documentation = element.documentation
for (o : element.operations) {
members += o.toMethod(o.name,
o.output.returnType
documentation = o.documentation
for (p : o.params) {
parameters += p.toParameter(p.name, p.parameterType)
body = [
val outputVarName = it.declareVariable(o, o.simpleName)
o.parameterType.serialize(o, it)
it.append(" " + outputVarName + " = null; // output parameter")
xbaseCompiler.compile(o.body, it, "void".getTypeForName(o), null)
it.generateFinalReturnStatement(o.output)
So you see, before doing the actual xbase compilation (with an injected
XbaseCompiler) I declare into the generated code an additional variable.
Here are again the relevant lines
body = [
Everything works fine (of course, I customized some scoping and
validation so that the generated code is consistent and checks work
correctly), but the debugger does not really work as expected: if I
enter, from Java code, into one of the generated Java methods the
debugger skips the first line of the original Operation (and it is kind
of messed up then)... I guess that's because the ITreeAppendable I use
for generating code should be somehow configured to skip the generated
Java line for the additional variable, shouldn't it? It is not clear,
however, how to use the ITreeAppendable API to achieve this (I guess the
same should be done for the additional final generated return statement).
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: [Xtext 2.3] Using the new debugging features [message #873040 is a reply to message #870258] Thu, 17 May 2012 07:31 Go to previous messageGo to next message
any help please?
thanks in advance
Lorenzo
On 05/07/2012 03:29 PM, Lorenzo Bettini wrote:
> Hi
> simplify)
> acceptor.accept(
> ).initializeLater [
> o.output.returnType
> body = [
> body = [
> thanks in advance
> Lorenzo
Re: [Xtext 2.3] Using the new debugging features [message #873077 is a reply to message #873040] Thu, 17 May 2012 09:14 Go to previous messageGo to next message
probably I figured this out myself... as soon as I'm sure about that
I'll post the solution :)
On 05/17/2012 01:31 PM, Lorenzo Bettini wrote:
> any help please?
> thanks in advance
> Lorenzo
>> Hi
>> simplify)
>> acceptor.accept(
>> ).initializeLater [
>> o.output.returnType
>> body = [
>> body = [
>> thanks in advance
>> Lorenzo
Re: [Xtext 2.3] Using the new debugging features [message #875431 is a reply to message #873077] Tue, 22 May 2012 14:36 Go to previous message
here's the article I wrote about this example
http://www.rcp-vision.com/?p=4089&lang=en
any comment is more than welcome :)
Lorenzo
>> any help please?
>> thanks in advance
>> Lorenzo
>>> Hi
>>> simplify)
>>> acceptor.accept(
>>> ).initializeLater [
>>> o.output.returnType
>>> body = [
>>> body = [
>>> statement).
>>> thanks in advance
>>> Lorenzo
Previous Topic:whitespaces not allowed in grammar
Next Topic:Templates for Xtext
Current Time: Wed Jul 23 16:16:46 EDT 2025
Powered by FUDForum. Page generated in 0.04392 seconds
