Home » Language IDEs » C / C++ IDE (CDT) » cdt 2.0M5 RC1?
cdt 2.0M5 RC1? [message #87451] Wed, 26 November 2003 09:29 Go to next message
I tried newly released cdt 2.0M5-RC1 with Eclipse 3.0M5. However, there
were a few problems on the process.
1. why org.eclipse.cdt.win32_2.0.0 is finding cdt 1.2? I did clean
installation after deleting previous version of Eclipse and cdt, so I had
no file of cdt 1.2. I saw the product configuration window from Help >
Software updates > Manage Configuration menu of Eclipse. There were a 'not
loaded' mark on 'Eclipse CDT (Windows) 2.0.0'. this item had a subitem of
'Eclipse CDT 1.2.0'. I wonder whether this is right or not. I tried to
modify 1.2.0 to 2.0.0 referring to error log file in my workspace. I
changed two files of features/org.eclipse.cdt.win32_2.0.0/features.xml and
plugins/org.eclipse.cdt.core.win32_2.0.0/fragment.xml. Then the unloaded
mark is disappered and 'Eclipse CDT (Windows) 2.0.0' items can be enabled.
But I don't make sure all works fine.
2. When I make a managed C project and build a helloworld.c file, which
contains only a printf function, then it seems that execution file cannot
be made such as helloworld.exe in release folder. I have an error message
on the way of building like this:
Build error
(Exec error:Launching failed)
I used MinGW on WinXP. This is my environment.
Eclipse: 3.0M5
Eclipse path: C:/GNU/Eclipse
MinGW: 3.1.0-1
MinGW path: C:/GNU/MinGW/bin
MSYS: 1.0.10-rc2
MSYS path: C:/GNU/msys/1.0/bin
Also the last two paths are in %PATH% of Windows environment variable.
When I tried simply 'gcc helloworld.c' on command window, it makes the
a.exe and the file works well.
I did all of configuration procedure in CDT tutorial, but I couldn't
obtain a executable file in Eclipse. I had also tried them in Eclipse
2.1.2 with CDT 1.2.0 with same MinGW packages before and confirmed that
exe file is produced well.
I don't know this is a bug of new CDT or Eclipse.
Thoughts?
Sincerely,
Leo.
Re: cdt 2.0M5 RC1? [message #87541 is a reply to message #87451] Thu, 27 November 2003 17:21 Go to previous messageGo to next message
Originally posted by: dschaefe.ca.ibm.com
Problem number one has been fixed in the new build.
Problem number two points out that the build command failed. Try opening a
DOS window and executing the build command there (probably 'make').
Doug
Jin-serk Baik wrote:
> Build error
> Eclipse: 3.0M5
> MinGW: 3.1.0-1
> MSYS: 1.0.10-rc2
> Thoughts?
> Sincerely,
> Leo.
Re: cdt 2.0M5 RC1? [message #87629 is a reply to message #87541] Fri, 28 November 2003 01:44 Go to previous messageGo to next message
Doug Schaefer wrote:
> Doug
Thank you. I tried newer version of CDT2.0M5. There was no problem in
compiling a helloworld code. but I found other some problems yet.
1. When I see the Product Configuration in Eclipse3.0, "Eclipse C/C++
Development Tools (Windows) 2.0.0" item is also not configured properly.
When I see the status of that item, it told the reason 'No plug-in:
"org.eclipse.cdt.core.win32" included at runtime.' However, the cdt itself
seems to work fine.
2. When I tried the Eclipse 3.0M5 and CDT 2.0M5 on Windows 2003 Enterprise
server, eclipse can't find gcc. I can't understand why, because gcc and
make works properly in the command window. %PATH% variable also has gcc
and make directory. I tried 'make all' in the release directory of
helloworld project in my workspace, and the compilation make a good exe
file. However, in eclipse, the phenomenon was not changed. on Windows XP
it works fine. What's the different between the OS? I also know eclipse is
not supported on Windows server 2003, however, I guess the bug can be
easily modified.
The message on 'problems' window on eclipse is following:
Severity Description Resource In Folder Location
*** [helloworld.o] Error 127 helloworld line -1
do you have any idea about that line number -1?
I tested them on these conditions:
OS: Windows Server 2003 Enterprise edition
Eclipse : 3.0 M5
Eclipse path: C:\GNU\Eclipse
CDT : 2.0 M5
MinGW : 3.1.0-1
MinGW path: C:\GNU\MinGW\bin
MSYS : 1.0.10-rc2
MSYS path : C:\GNU\msys\1.0\bin
I hope your help once again. Thank you.
Re: cdt 2.0M5 RC1? [message #87678 is a reply to message #87629] Fri, 28 November 2003 05:22 Go to previous messageGo to next message
Rather paste the output of the C-Build View then the task entry.
>>Hi,
>>Thanks,
>>Doug
> seems to work fine.
> easily modified.
> Eclipse : 3.0 M5
> CDT : 2.0 M5
> MinGW : 3.1.0-1
> MSYS : 1.0.10-rc2
Re: cdt 2.0M5 RC1? [message #87708 is a reply to message #87678] Fri, 28 November 2003 06:15 Go to previous messageGo to next message
This is the copy of C-Build view.
make all
make: gcc: Command not found
make: *** [helloworld.o] Error 127
gcc -O3 -gstabs -Wall -c -o helloworld.o ../helloworld.c
Build complete for project helloworld
As looking the messages itself, it seems that the path environment doesn't
have the gcc path. However, when I tried 'make all' in command window, I
can obtain a exe file without any error message.
Sincerely,
Leo
Re: cdt 2.0M5 RC1? [message #87722 is a reply to message #87708] Fri, 28 November 2003 08:10 Go to previous messageGo to next message
Go into a console window, and call "set PATH".
Are the MinGW and msys paths really listed?
There should be C:/MinGW/bin and C:/msys/1.0/bin listed.
Check your MinGW installation. Restart Eclipse after setting/changing your PATH
variable,
since started appliactions do not get new path settings forwarded.
> make all
> Sincerely,
> Leo
Re: cdt 2.0M5 RC1? [message #87738 is a reply to message #87722] Fri, 28 November 2003 07:42 Go to previous messageGo to next message
As I wrote, I already checked them.
I think that eclipse or cdt don't understand path variable on windows
server 2003.
I tried reinstallation of MinGW or Eclipse or CDT several times.
All trials show the same result.
PATH
> variable,
Re: cdt 2.0M5 RC1? [message #87753 is a reply to message #87738] Fri, 28 November 2003 09:25 Go to previous messageGo to next message
Maybe you can try setting the paths with backslashs instead of slashs?
C:\MinGW\bin instead of C:/MinGW/bin.
And try to set them system wide instead of User specific. In my Win2k there are two
fields. I got the feeling setting them in the top (per User) does not update the
system wide (maybe until reboot).
I don't think, that setting PATHs in Win2k3 is anything really different than in
Win2k!
> server 2003.
> PATH
>>variable,
Re: cdt 2.0M5 RC1? [message #87776 is a reply to message #87753] Fri, 28 November 2003 08:51 Go to previous messageGo to next message
I really appreciate your kind replies. I agree what you thought. But, I
have tried several tests on Win2k3. Also I tried backslashs instead of
slashs, and vice versa. And, system wide variable are also tried (PATH
variable is not a user specific but system wide).
I can't think what should I do more. :~(
> C:MinGWbin instead of C:/MinGW/bin.
are two
the
than in
> Win2k!
Re: cdt 2.0M5 RC1? [message #87823 is a reply to message #87776] Fri, 28 November 2003 11:36 Go to previous messageGo to next message
I haven't tried on Win2K3, but have you tried a good ol' fashioned reboot
since updating your Path? Maybe the old version of the path is still
persisting
somewhere, and Eclipse is getting the old path...
Just a thought,
- Brent
"Jin-serk Baik" <leo@photonet.kaist.ac.kr> wrote in message
news:bq7jto$ar$1@eclipse.org...
there
> are two
update
> the
> than in
> > Win2k!
Re: cdt 2.0M5 RC1? -- I found what's wrong!!!!! [message #87838 is a reply to message #87776] Fri, 28 November 2003 11:58 Go to previous message
I found what's wrong.
Eclipse can't understand the %PATH% variable of which values is over 255
characters.
When I reduce the length of PATH value, cdt works fine. No problem in
compilation.
I think this is a bug of eclipse or cdt, isn't this?
Previous Topic:content assist in C++ editor
Next Topic:CDT forget a little
Current Time: Sat Jul 26 06:14:48 EDT 2025
Powered by FUDForum. Page generated in 0.45699 seconds
