How to set variables when using Excel as source [message #874806] |
Mon, 21 May 2012 11:28  |
Hi all,
is it possible to take values out of an Excel sheet as data source and use these as variables?
In Jubula data sets I can give VAR1, VAR2, VARn as Variables in data sets, which then are set to different values when executing the test case (e.g. columns in a table).
When trying this with Excel, where VAR1, VAR2, VARn are values of a specific column in the sheet, this does not seem to work. The test case (which is set to get a variable at the specific position) itself does not complain, but the variables are not set after running it, as they were with Jubula data sets.
Am I doing something wrong, or is it only possible to get Strings out of the Excel data set, and there is no possibility to use these as variables?
(I know we are discouraged to use Excel in favor of Jubula data sets, but it just seems much more practicable when using a larger count of columns with data dependencys amongst many sets)
FUDForum. Page generated in 0.05172 seconds
