"Operation Failed" during remote ftp access [message #874556] |
Mon, 21 May 2012 02:34  |
Hi everybody,
as you figured i'm a very beginner and currently stuck at a small issue.
I'm trying to remote access my ftp server using "TM and RSE 3.1.1" from
download.eclipse org/dsdp/tm/updates/3.0
and get the following error when i try to access it:
"Operation Failed. File system input or output error."
I have the exact same eclipse version with this plugin on my other PC and it works just fine. The only difference is, on this machine i additionally have a SVN software installed for eclipse.
i'm using eclipse indigo on windows 7.
If you need anything else (logs or something) let me know.
Thanks in advance for your help.
Best regards
Sumit
Re: "Operation Failed" during remote ftp access [message #878012 is a reply to message #877988] |
Mon, 28 May 2012 06:01   |
Well I guess It will be better if I ellaborate a little bit.
This is really odd specially because the RSE FTP used to work flawlessly, when all out of a sudden stopped working , and I don't think I did anything to break it.
Basically when I connect trough ftp, everything is fine, it gets connected, because I can see in the console the server responding toand the last ftp command sent to the server is a PASV, and the server doesnt seem to respond.(Although it does with an "227 entering passive mode" but I can only see this monitoring the connection with wireshark, not in the console).
I've tried changing the mode to not passive, and I get same result , but obviously without PASV command.
I don't think the priblem involves a firewall or a server setting, I have connected with some other software with same ftp settings included passive mode, and I haven't had any trouble.
As I said I tried monitoring the connection with wireshark and I noticed that right after the last successful message, the RSE sends a message that wireshark marks as having an "incorrect ip checksum (maybe caused by 'ip checksum offload')".I'm not a tcp/ip expert, I just thought It could give some extra information to any kind soul that is able to help us
Re: "Operation Failed" / "Connection reset by peer: socket write error" [message #899024 is a reply to message #874556] |
Mon, 30 July 2012 04:38  |
Hello Guys
Using the older vm really do it for me too (thank you very much for this hint). But there must be another secret. I am using different FTP connections to different FTP servers and some of them working others not. So this behavior must also depend on the servers (settings? software? how to figure out which server/settings is installed on a host?)
Ok, iam not the "Serverman" but maybe this could be another brick to build a solution.
adios, Stefan
[Updated on: Mon, 30 July 2012 05:10] by Moderator
FUDForum. Page generated in 0.33590 seconds
