Re: How to stop already running OSGi frameworks from IDE [message #883284 is a reply to message #883077] |
Fri, 08 June 2012 03:52  |
Hi Crag,
it doesn't sound to me like the same issue which I had... In my case it
was all about my Eclipse IDE UI user education because I didn't know
that Console view has a toolbar combobox to switch among running
processes. Or that I can see them from Debug perspective.
Libor
On 06/07/2012 09:59 PM, craig mc wrote:
> I ran across the same issue and it took me a while to figure it out. It
> appears that the first OSGi plugin project you create will also create
> an OSGi Framework Run Configuration which defaults to the same name as
> the project. And in my case it (or I) had set that first bundle to
> auto-start in the run config settings.
> So even though you are clicking run from another plugin project, it is
> still running the same run configuration and auto-starting other bundles.
> So you need to right click on your project, go to Run As and choose Run
> Configurations. The find the OSGi run confi and see which bundles are
> set to auto-start.. And in my case I renamed the Run Config to something
> generic to remove the confusion.
FUDForum. Page generated in 0.03935 seconds
