Home » Eclipse Projects » Virgo » HELP ABOUT Spring STS 3.0 with virgo tomcat server
HELP ABOUT Spring STS 3.0 with virgo tomcat server [message #874266] Sun, 20 May 2012 06:33 Go to next message
Here is my problem:when i tried to start the virgo server 3.0.3.realese it bumps out
[2012-05-20 19:31:02.648] startup-tracker <KE0001I> Kernel starting.
[2012-05-20 19:31:03.148] kernel-dm-5 <RP0100W> The repository 'ext' is not available.
[2012-05-20 19:31:04.131] startup-tracker <KE0002I> Kernel started.
[2012-05-20 19:31:04.147] system-artifacts <DE0700E> Cannot find plan 'org.eclipse.virgo.kernel.userregion.springdm' version range '[0.0.0, oo)' in repository 'stage-usr'.
[2012-05-20 19:31:04.147] system-artifacts <DE0700E> Cannot find plan 'org.eclipse.virgo.web.tomcat' version range '[0.0.0, oo)' in repository 'stage-usr'.
[2012-05-20 19:31:04.147] system-artifacts <UR0002E> User region failed while deploying initial artifacts. Shutting down.
[2012-05-20 19:31:04.272] System Bundle Shutdown <KE0010I> Shutdown initiated.
my envirnment is jdk 1.6 u32 64bit, win7 64bit. Does anyone have ever encountered this ?Please help.Thanks very much~~
Re: HELP ABOUT Spring STS 3.0 with virgo tomcat server [message #874608 is a reply to message #874266] Mon, 21 May 2012 04:42 Go to previous message
Check that the folder VIRGO_HOME/repository/ext exists and that it's not read only, it appears that the kernel cannot access this folder. Try to re download the VTS zip and re extract it .
Sincerly.
[Updated on: Mon, 21 May 2012 04:44] by Moderator
Previous Topic:3.5.0M4 Blueprint extender failing to create context
Next Topic:Spring MVC Web-bundle no context created
Current Time: Thu Jul 24 11:56:46 EDT 2025
Powered by FUDForum. Page generated in 0.04433 seconds
