Home » Archived » Buckminster » Unable to load runtime repository
Unable to load runtime repository [message #874169] Sun, 20 May 2012 00:53 Go to next message
A while back I started to use a bundle pool for my various IDE installations. Now Buckminster logs the following message
to the console during the import of my MSpec:
Unable to load runtime repository: No repository found at file:/C:/develop/bin/eclipse-cdo/.
I guess that is because my IDE installation does not contain features/plugins folders anymore. It ssems that this
doesn't lead to severe problems but it strikes me that the usage of the bundle pool could make the resolution/download
phases much faster. Would that be right? Is there something I can do?
Cheers
/Eike
http://www.esc-net.de
Re: Unable to load runtime repository [message #874182 is a reply to message #874169] Sun, 20 May 2012 01:13 Go to previous messageGo to next message
Correction:
It seems that the console message is in fact an indication for a fatal problem. The import operation does not continue
after the message.
Cheers
/Eike
Am 20.05.2012 06:53, schrieb Eike Stepper:
> message to the console during the import of my MSpec:
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: Unable to load runtime repository [message #874186 is a reply to message #874169] Sun, 20 May 2012 01:13 Go to previous messageGo to next message
Correction:
after the message.
Cheers
/Eike
> Cheers
> /Eike
Re: Unable to load runtime repository [message #874189 is a reply to message #874169] Sun, 20 May 2012 01:13 Go to previous messageGo to next message
Correction:
after the message.
Cheers
/Eike
> Cheers
> /Eike
Re: Unable to load runtime repository [message #874191 is a reply to message #874169] Sun, 20 May 2012 01:13 Go to previous messageGo to next message
Correction:
after the message.
Cheers
/Eike
> Cheers
> /Eike
Re: Unable to load runtime repository [message #874262 is a reply to message #874182] Sun, 20 May 2012 06:21 Go to previous messageGo to next message
That's definitely a bug. The runtime repo should be found regardless of location and since using it is meant to be an
optimization only (it's used for materialization, not for resolution), an error should't cause problems.
- thomas
On 05/20/2012 07:13 AM, Eike Stepper wrote:
> Correction:
> after the message.
> Cheers
> /Eike
>> Hi,
>> Cheers
>> /Eike
Re: Unable to load runtime repository [message #874519 is a reply to message #874262] Mon, 21 May 2012 00:32 Go to previous message
Am 20.05.2012 12:21, schrieb Thomas Hallgren:
> optimization only
I've filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=380097
Sorry, that's indeed true.
I can no longer reproduce that the operation stops at that point. The console message is reproducible, though.
Cheers
/Eike
> - thomas
>> Correction:
>> after the message.
>> Cheers
>> /Eike
>>> Hi,
>>> Cheers
>>> /Eike
Previous Topic:Unable to load runtime repository
Next Topic:Ca y CQuery refer to another CQuery rather than an RMap?
Current Time: Sat Jul 26 08:08:38 EDT 2025
Powered by FUDForum. Page generated in 0.20596 seconds
