Home » Language IDEs » ServerTools (WTP) » Problem generating Axis2 web service client - Element QName is null for TestServiceTestException
Problem generating Axis2 web service client - Element QName is null for TestServiceTestException [message #841622] Wed, 11 April 2012 11:00 Go to next message
I'm looking to create both a web service and the consuming client using Axis2 and the web tools platform. In particular I've based my work thus far off the tutorial on the top Google result for "Creating a bottom-up Axis2 Web service" (I'd post a link but the forum blocks it). Roughly it creates a bottom up web service and then consumes it by passing the WSDL in to the new web service client option in the WTP.
However problems occur when I try adding exceptions. If I generate a bottom up Axis 2 web service from a class with an exception and then try to generate a client I get this exception message.
Exception occurred during code generation for WSDL  : org.apache.axis2.wsdl.codegen.CodeGenerationException: org.apache.axis2.wsdl.codegen.CodeGenerationException: java.lang.RuntimeException: Element QName is null for TestServiceTestException!
    at org.eclipse.jst.ws.axis2.consumption.core.command.Axis2ClientCodegenCommand.execute(Axis2ClientCodegenCommand.java:222)
    at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.runCommand(CommandFragmentEngine.java:419)
    at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.visitTop(CommandFragmentEngine.java:359)
    at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.moveForwardToNextStop(CommandFragmentEngine.java:254)
    at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager$6.run(SimpleCommandEngineManager.java:294)
    at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
    at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
    at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1029)
    at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager.runForwardToNextStop(SimpleCommandEngineManager.java:264)
    at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.runForwardToNextStop(WizardPageManager.java:91)
    at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.performFinish(WizardPageManager.java:262)
    at org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizard.performFinish(DynamicWizard.java:382)
    at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
    at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
    at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
    at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
    at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
    at org.eclipse.jface.window.Window.open(Window.java:801)
    at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:257)
    at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:277)
    at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
    at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
    at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
    at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
    at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
    at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
    at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
    at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
    at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
    at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
    Caused by: org.apache.axis2.wsdl.codegen.CodeGenerationException: org.apache.axis2.wsdl.codegen.CodeGenerationException: java.lang.RuntimeException: Element QName is null for TestServiceTestException!
    at org.apache.axis2.wsdl.codegen.CodeGenerationEngine.generate(CodeGenerationEngine.java:293)
    ... 61 more
    Caused by: org.apache.axis2.wsdl.codegen.CodeGenerationException: java.lang.RuntimeException: Element QName is null for TestServiceTestException!
    at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.emitStub(AxisServiceBasedMultiLanguageEmitter.java:537)
    at org.apache.axis2.wsdl.codegen.CodeGenerationEngine.generate(CodeGenerationEngine.java:282)
    ... 61 more
    Caused by: java.lang.RuntimeException: Element QName is null for TestServiceTestException!
    at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.getFaultParamElements(AxisServiceBasedMultiLanguageEmitter.java:2925)
    at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.getFaultElement(AxisServiceBasedMultiLanguageEmitter.java:2844)
    at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.generateMethodElement(AxisServiceBasedMultiLanguageEmitter.java:2366)
    at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.loadOperations(AxisServiceBasedMultiLanguageEmitter.java:2242)
    at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.createDOMDocumentForCallbackHandler(AxisServiceBasedMultiLanguageEmitter.java:1232)
    at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.writeCallBackHandlers(AxisServiceBasedMultiLanguageEmitter.java:1198)
    at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.emitStub(AxisServiceBasedMultiLanguageEmitter.java:500)
    ... 62 more
A cut down service that exposes the problem is below.
package test;
public class TestService {
	public String returnOdd(int value) throws TestException
		if(value % 2 == 1)
			return "" + value;
		else
			throw new TestException(42);
package test;
public class TestException extends Exception {
	private static final long serialVersionUID = 6251838669400665002L;
	private int exceptionCode;
	public TestException(int exceptionCode)
    	this.exceptionCode = exceptionCode;
    public String getMessage()
    	return "Exception code was " + exceptionCode;
Has anyone encountered this before? It seems that the WSDL being generated by the service isn't able to be consumed by the client generator. If this is the case is there some kind of configuration option to make them speak the same language?
Gareth
Re: Problem generating Axis2 web service client - Element QName is null for TestServiceTestException [message #874084 is a reply to message #841622] Sat, 19 May 2012 19:30 Go to previous messageGo to next message
Hello! Facing the same problem... Is there any solution to that?
Re: Problem generating Axis2 web service client - Element QName is null for TestServiceTestException [message #949746 is a reply to message #874084] Fri, 19 October 2012 04:47 Go to previous message
There is a bug in Axis's Jira that will be fixed in 1.7.0 - issues.apache.org/jira/browse/AXIS2-5060
To work around the problem on the last page of the client generation wizard you should select Soap11Endpoint or Soap12Endpoint on the Port Name field.
George
Previous Topic:Content Assist doesn't work 100% for tagx
Next Topic:eclipse - beehive
Current Time: Fri Jul 25 18:21:33 EDT 2025
Powered by FUDForum. Page generated in 0.06894 seconds
