Single-sourcing with E4 apps? [message #874062] |
Sat, 19 May 2012 17:58  |
Does RAP support E4 applications based on the programming model where you use E4's provided E4Application class instead of setting up your own Display and workbench? It seems hard to move the initializations done in the E4Application class into an EntryPoint in the way people seem to do that with 3.x-apps...
Besides, from reading bugzilla I gather that there might already be an entry point, or at least ApplicationConfiguration, registered for the E4 app? I am led to believe that's the case because I get the following exception when I try to register my own ApplicationConfiguration with EntryPoint "org.osgi.service.http.NamespaceException: The alias '/rwt-resources' is already in use."
If the E4 app already registers an entry point, how can I launch the RAP app based on that entry point? If I just do Run without specifying anything, I get an error saying that entry point /default does not exist...
[Updated on: Sat, 19 May 2012 17:59] by Moderator
FUDForum. Page generated in 0.04546 seconds
