Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Unstable behavior when using a query from an imported module
[Acceleo] Unstable behavior when using a query from an imported module [message #874034] Sat, 19 May 2012 16:10 Go to next message
Hello, I hope you can help me.
I have two modules in the same package of my project. The module A contains the following query:
[query public getOutputs(anAction: Action): Sequence(OutputPin) =
	anAction.output
	->select(op: OutputPin | op.isBBOutput())
	->asSequence()
Then, I import module A in module B and use getOutputs in the following query in B:
[query public getOutputsMultiplicities(anOperation: OpaqueAction): Sequence(Integer) =
	anOperation.getOutputs()
	->collect(op: OutputPin | op.getMultiplicity())
	->asSequence()
The behavior is unstable when building the project because Acceleo indicates the following error in getOutputsMultiplicities():
Iterator variable must have same type as source element type (anOperation.getOutputs()->collect(op : OutputPin | op.getMultiplicity())) Iterator variable must have same type as source element type (anOperation.getOutputs()->collect(op : OutputPin | op.getMultiplicity()))
When I clean and build the project the error disappears, but reappears whenever I do any modification in the file containing module B.
¿Any idea what is going on?
Thanks.
Re: [Acceleo] Unstable behavior when using a query from an imported module [message #874050 is a reply to message #874034] Sat, 19 May 2012 17:01 Go to previous messageGo to next message
This sounds like problems I had. Acceleo 3.3M7 fixed them.
Ed Willink
> anAction.output
> ->asSequence()
> Sequence(Integer) =
> ->asSequence()
> Thanks.
Re: [Acceleo] Unstable behavior when using a query from an imported module [message #874076 is a reply to message #874050] Sat, 19 May 2012 18:56 Go to previous messageGo to next message
Hi Ed.
Thanks for answering. According to the information I gathered, I have Acceleo SDK 3.1.3 in my Eclipse Modeling Tools Version: Indigo Service Release 2. A search for updates indicates that no updates are available. How can I install Acceleo 3.3M7?
Thanks.
Re: [Acceleo] Unstable behavior when using a query from an imported module [message #874128 is a reply to message #874050] Sat, 19 May 2012 22:42 Go to previous messageGo to next message
I installed Acceleo 3.3.0 M7 from the following repository:
http://download.eclipse.org/releases/juno
The problem seems to be no more. However, the perspective list tab in my workspace got a bit messy; no big deal. I installed Eclipse Juno M7 and all of my modeling infrastructure (Papyrus, Acceleo, OCL Editors and ATL), but when I opened my models in Papyrus, their layout changed, the icons for the applied stereotypes went small, and some elements were MISSING (although not in the .uml file in XMI).
I hope the Juno team and the Papyrus team fix issues by the official release day of Juno.
Thanks.
Re: [Acceleo] Unstable behavior when using a query from an imported module [message #874193 is a reply to message #874128] Sun, 20 May 2012 01:33 Go to previous message
The milestones enable enthusiasts to help in the debugging.
Please report Papyrus issues to the Papyrus team. I know that they've
been doing some significant restructuring so there may be things that
they've missed.
Ed Willink
> Thanks.
Previous Topic:[XPAND] Traverse all elements of a class
Next Topic:[Acceleo] Transversal tree generation
Current Time: Wed Jul 23 07:44:26 EDT 2025
Powered by FUDForum. Page generated in 0.10864 seconds
