Home » Modeling » UML2 » UML2/EMF standalone
UML2/EMF standalone [message #873950] Sat, 19 May 2012 11:09 Go to next message
i'm trying to identify minimum set of UML2/EMF jars for my project.
The only functionality i need is beeing able to load uml models from xmi
files and then access those model elements.
Currently, i've included following jars (they are from old eclipse
version, but i'll update to equivalent jars from juno):
org.eclipse.emf.ecore_2.5.0.v200906151043.jar
org.eclipse.emf.ecore.xmi_2.5.0.v200906151043.jar
org.eclipse.emf.common_2.5.0.v200906151043.jar
org.eclipse.emf.exporter_2.5.0.v200906151043.jar
org.eclipse.emf.importer_2.5.0.v200906151043.jar
org.eclipse.emf_2.5.0.v200906151043.jar
org.eclipse.uml2.common_1.5.0.v200905041045.jar
org.eclipse.uml2.uml.ecore.exporter_2.3.0.v200905041045.jar
org.eclipse.uml2.uml.ecore.importer_2.3.0.v200905041045.jar
org.eclipse.uml2.uml.resources_3.0.0.v200906011111.jar
org.eclipse.uml2.uml_3.0.1.v200908281330.jar
org.eclipse.uml2_3.0.0.v200905041045.jar
org.eclipse.emf.converter_2.5.0.v200906151043.jar
org.eclipse.equinox.common_3.5.1.R35x_v20090807-1100.jar
org.eclipse.emf.codegen.ecore_2.5.0.v200906151043.jar
org.eclipse.emf.mapping.ecore2xml_2.5.0.v200906151043.jar
org.eclipse.emf.ecore.edit_2.5.0.v200906151043.jar
org.eclipse.emf.edit_2.5.0.v200906151043.jar
org.eclipse.uml2.common.edit_1.5.0.v200905041045.jar
org.eclipse.uml2.uml.edit_3.0.0.v200905041045.jar
org.eclipse.emf.ecore.change_2.5.0.v200906151043.jar
Trying to remove any of those jars from classpath results in different
exceptions. But i think, i just do that in wrong sequence, and i really
don't need some of jars. For example, codegen.ecore_2.5.0,
equinox-commmon or mapping.ecore_2.5.0. Any suggestions to filter out
unnecessary jars would be very helpful.
Thanks in advance.
Re: UML2/EMF standalone [message #873966 is a reply to message #873950] Sat, 19 May 2012 12:08 Go to previous messageGo to next message
importer/exporter/change can probably go.
mapping is needed for CMOF.
Use a plugin so that you have a manifest and then show the plugin
dependency hierarchy, and the remove unused dependencies tool.
Ed Willink
On 19/05/2012 16:09, Emil Huseynli wrote:
> xmi files and then access those model elements.
> really don't need some of jars. For example, codegen.ecore_2.5.0,
> Thanks in advance.
Re: UML2/EMF standalone [message #873977 is a reply to message #873966] Sat, 19 May 2012 12:54 Go to previous messageGo to next message
just removed emf_2.5.0 and everything seems still to work, very strange...
what about equinox.common?
not a trivial task for me at the moment
Re: UML2/EMF standalone [message #873985 is a reply to message #873950] Sat, 19 May 2012 13:24 Go to previous messageGo to next message
Reduced jar-set to
Existing code works so far.
Is it possible that with removing all those jars i've excluded some
functionality related to loading uml models and traversing them?
On 19.05.2012 17:09, Emil Huseynli wrote:
> Thanks in advance.
Re: UML2/EMF standalone [message #873986 is a reply to message #873950] Sat, 19 May 2012 13:29 Go to previous messageGo to next message
In the TextUML Toolkit and AlphaSimple projects, which create and read UML models in batch mode (no "edit" support), these are all EMF and UML plugins I needed:
From EMF, all I use is:
org.eclipse.emf.common_2.7.0.v20120127-1122.jar
org.eclipse.emf.ecore_2.7.0.v20120127-1122.jar
org.eclipse.emf.ecore.xmi_2.7.0.v20120127-1122.jar
org.eclipse.emf.mapping.ecore2xml_2.7.0.v20120130-0943.jar
From UML, all I use is:
org.eclipse.uml2.common_1.6.0.v201105021727.jar
org.eclipse.uml2.uml_3.2.100.v201108110105.jar
org.eclipse.uml2.uml.resources_3.1.100.v201008191510.jar
These are OSGi-based applications though - however, I don't see how more would be necessary just to support a standalone application.
Re: UML2/EMF standalone [message #873992 is a reply to message #873986] Sat, 19 May 2012 13:50 Go to previous messageGo to next message
thanks, i've removed this jar too
and seems nothing get broken so far
> plugins I needed:
Re: UML2/EMF standalone [message #875269 is a reply to message #873992] Tue, 22 May 2012 08:47 Go to previous messageGo to next message
Hi, Emil,
That JAR is just a branding plug-in. It contains the source models of
the UML from OMG and some custom codegen templates used by the UML2
project, but no code.
Christian
>> plugins I needed:
Re: UML2/EMF standalone [message #875271 is a reply to message #875269] Tue, 22 May 2012 08:54 Go to previous message
Oh, and the source models and templates are only included in the source
build, not the binary distribution, anyways …
cW
On 2012-05-22 12:47:59 +0000, Christian W. Damus said:
> Hi, Emil,
> Cheers,
> Christian
>>> plugins I needed:
Previous Topic:UML2 3.x Resources with 4.x
Next Topic:Store model in database
Current Time: Wed Jul 23 11:54:50 EDT 2025
Powered by FUDForum. Page generated in 0.51740 seconds
