Home » Archived » BIRT » Use computed column to concatenate data set data
Use computed column to concatenate data set data [message #872826] |
Wed, 16 May 2012 18:30  |
I am trying to create a string which is a concatenation of all the data in a data set.
For example, I have a data set "row[FirstName]" and it has data of "John", "Alice" and "Mary". I would like to create a string which is "John, Alice, Mary" (with comma in between data).
I am thinking about using computed column function in data set to achieve this but don't know how to grab each data from the data set.
please advise.
Neil
Re: Use computed column to concatenate data set data [message #873654 is a reply to message #873026] |
Fri, 18 May 2012 15:14   |
Hi Thomas,
Thank you for your comment and it works.
I have another question.
I have a data set with this information
Child data set
Key|Value|ID|Concatenation
AAA|BBBBB|01|AAABBBBB, CCCDDDDD
CCC|DDDDD|01|AAABBBBB, CCCDDDDD
The goal of the concatenation is to concatenate all key and value columns into one string which works fine.
I have another data set like this
Parent data set
Name|ID
Bill|01
I need to create a join data set with ID as the join key and the result looks like
Parent:Name|Parent:ID|Child:Key|Child:Value|Child:ID|Child:Concatenation
Bill| 01| AAA| BBBBB| 01| AAABBBBB, CCCDDDDD
Bill| 01| CCC| DDDDD| 01| AAABBBBB, CCCDDDDD
However, I would like to have the result to look like
I am not gonna display Child:Key and Child:Value in my report; therefore, I don't mind having/not having them in the final result set. The whole purpose is to have one parent to have its "Key + Value" concatenated in one string; therefore, having two rows defeats the purpose as I put them in the detailed row of a table, both rows will show up. I am thinking I should keep just one row in the child result set; so that, the final result set will have one row only; however, I am not sure how to do it. Please advise.
Neil
Re: Use computed column to concatenate data set data [message #876073 is a reply to message #873654] |
Wed, 23 May 2012 17:11   |
Neil
Did you get this to work?
Jason
On 5/18/2012 3:14 PM, Neil Wang wrote:
> Hi Thomas,
> Child data set
> Parent data set
> Name|ID
> Bill|01
> looks like
> Neil
Current Time: Sat Jul 26 23:40:49 EDT 2025
Powered by FUDForum. Page generated in 0.04705 seconds
