Home » Eclipse Projects » Remote Application Platform (RAP) » Change default meta headers in M7
Change default meta headers in M7 [message #873544] Fri, 18 May 2012 09:49 Go to next message
Hello!
We would like to know how we could change the default values of meta headers of the HTML page.
We are currently trying to make our application work well on the iPad and upgraded to M7 when it released. We would like to enable the iPad zoom and need to change the default content of the viewport meta tag for this.
We would like to change it from
<meta name = "viewport" content = "initial-scale = 1.0, minimum-scale = 1.0, maximum-scale=1.0" >
to
<meta name = "viewport" content = "initial-scale = 1.0, user-scalable=yes >
Is this possible?
Tiburon
Edit: We used the additonalHeaders extension before, but Safari does not seem to enable zoom if two tags are used.
[Updated on: Fri, 18 May 2012 09:52] by Moderator
Re: Change default meta headers in M7 [message #875184 is a reply to message #873544] Tue, 22 May 2012 05:17 Go to previous message
Hi Tiburon,
You can add meta headers but currently not overwrite them. If you add
your header, you'll end up with both headers present in the document.
Chances are that your settings win.
To add a meta header, add an "additionalHeaders" element to your
branding extension, or, if you use the ApplicationConfiguration API, use
WebClient.HEAD_HTML as key in your entrypoint properties.
HTH, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Previous Topic:MenuManager on right click doesn't work properly with 1.5M6
Next Topic:URL with token
Current Time: Sat Jul 26 11:35:10 EDT 2025
Powered by FUDForum. Page generated in 0.04163 seconds
