Home » Eclipse Projects » Remote Application Platform (RAP) » Multi User Application - Guidelines?
Multi User Application - Guidelines? [message #873481] Fri, 18 May 2012 06:33 Go to next message
we are planning to develop a multi user application in the near future. Multi user means, you can login and every unique user has its own persistent workspace.
As far as i know, something like that is not implemented yet.
Are there best practices,guidelines or something like that available?
Re: Multi User Application - Guidelines? [message #875174 is a reply to message #873481] Tue, 22 May 2012 05:11 Go to previous message
Just to avoid misunderstandings, let me just point out that every RAP
application is, of course, a multi-user application. RAP also supports
user-specific, persistent settings using the setting store, see
RWT.getSettingStore().
If I understand correctly, you plan to implement an Eclipse workspace in
a RAP application, right? To do so, you will have to implement at least
the core.resources plug-in for RAP. To my knowledge, this hasn't been
done yet. So, apart from the usual advices (care with static fields,
singletons, etc.) there are no specific guidelines for this task. If you
haven't done yet, you might want to check out our single sourcing guide
[1] - a bit old, but the advices given there are still valid.
Ralf
[1] http://eclipsesource.com/en/info/rcp-rap-single-sourcing-guideline/
Ralf Sternberg
Twitter: @EclipseRAP
Previous Topic:memory leaks
Next Topic:MenuManager on right click doesn't work properly with 1.5M6
Current Time: Mon Jul 21 02:03:35 EDT 2025
Powered by FUDForum. Page generated in 0.06885 seconds
