Home » Modeling » TMF (Xtext) » Spell checking for Strings(Activate spell checking for Strings in Xtext models)
Spell checking for Strings [message #551406] Fri, 06 August 2010 06:07 Go to next message
I'ld like to enable spell checking in my dsl for some Elements, like Strings. I think about two possible ways.
1. Writing a cusom reconciler, which enable spell checking and delegates to the XtextReconciler. In this approach I've to access the parsed model, to see the elements at the changed positions.
2. Write a custom Validator which calls the spell checker, for the Strings of one element. Because the spell checking result is neither a error nor a warning or an information, but an additional type of marker, I need a way to get the annotationModel in the validator.
Is there a third, better way, for doing this?
Benjamin
Re: Spell checking for Strings [message #551414 is a reply to message #551406] Fri, 06 August 2010 06:36 Go to previous messageGo to next message
Hi Benjamin,
I'ld try to collect the regions of all strings and comments, that should
be checked, in the validator. Use SpellingService#check() with a mocked
document that supports the minimal required methods (like
getLegalLineDelimiters and get(offset, length)) and a
ISpellingProblemCollector that transforms the spelling problems into
warnings.
Sebastian
Am 06.08.10 12:07, schrieb Benjamin Schwertfeger:
> Hello,
> Regards,
> Benjamin
Re: Spell checking for Strings [message #551859 is a reply to message #551414] Mon, 09 August 2010 15:54 Go to previous messageGo to next message
thanks for the recommendation. I tried to implement a JavaCheck for this scenario, but the SpellingService is inside the ui packages and needs the viewer.
I took the first approach and extended the xtextReconciler to set the document for the spellingReconciler. I modified the SpellingProblemCollector and took the Range from the Terminals in the ParseResult to check only user modifiable text.
Benjamin
Re: Spell checking for Strings [message #552111 is a reply to message #551859] Tue, 10 August 2010 17:13 Go to previous messageGo to next message
Hi Benjamin,
you are free to extend the java validator in the ui package although it
would not check the spelling in the standalone scenario.
Sebastian
Am 09.08.10 21:54, schrieb Benjamin Schwertfeger:
> Hello,
> the viewer.
> Benjamin
Re: Spell checking for Strings [message #873031 is a reply to message #551859] Thu, 17 May 2012 07:07 Go to previous messageGo to next message
Do you mind to share your implementation? I'm facing the same issue here with Xtext 2.1 and I'm struggling trying to replicate your solution. Some code will probably help.
Re: Spell checking for Strings [message #873074 is a reply to message #873031] Thu, 17 May 2012 09:13 Go to previous message
Wait for Xtext 2.3.0 it has built in support for that.
Previous Topic:Validating unused declarations
Next Topic:Problems with formatting rules
Current Time: Fri Jul 25 00:00:06 EDT 2025
Powered by FUDForum. Page generated in 0.31323 seconds
