Home » Modeling » TMF (Xtext) » XText 2.3.0M6 problem with setInitializer(setInitializer does not work in 2.3.0M6?)
XText 2.3.0M6 problem with setInitializer [message #872824] Wed, 16 May 2012 18:28 Go to next message
I am trying to upgrade from XText 2.2.1 to 2.3.0M6 (2.3.0.v201205081025), but having trouble with the new setBody and setInitializer methods.
For setBody, I can usually just wrap an 'append(...)' around the body and it works okay, but setInitializer is more recalcitrant.
For example, in the following code:
val atoms = new ArrayList<String>()
// Generate array of orderby integer values
members += table.orderby.toField("ORDERBY", addArrayTypeDimension(intType)) [
^static = true
^final = true
//was: initializer = ['''{ «atoms.join(", ")», ORDER_END }''']
initializer = [append('''{ «atoms.join(", ")», ORDER_END }''')]
the initializer=... line gives the error:
Incompatible types. Expected org.eclipse.xtext.xbase.XExpression but was (null)=>org.eclipse.xtext.xbase.compiler.output.ITreeAppendable
(even though hovering over 'initializer' says that it is using the void setInitializer(JvmField field, Procedure1<ITreeAppendable> strategy) version of setInitializer.)
Can anyone tell me how to fix this?
Is there any documentation about the changes from 2.2.1 to 2.3?
Mark
Re: XText 2.3.0M6 problem with setInitializer [message #873095 is a reply to message #872824] Thu, 17 May 2012 09:42 Go to previous messageGo to next message
i guess the type inferrer is still not that good so what about giving it some hints
val field = f.toField(f.name, f.type)
							val (ITreeAppendable) => void init = [append('''''')]
							initializer = init
Of course a bugzilla for a better inferrer in this case is welcome i guess.
~Christian
Re: XText 2.3.0M6 problem with setInitializer [message #873997 is a reply to message #872824] Sat, 19 May 2012 14:08 Go to previous message
Please file a bugzilla.
Sven
Am 5/17/12 12:28 AM, schrieb Mark Utting:
> ^static = true
> ^final = true
> Thanks
> Mark
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Previous Topic:Lookahead value of xtext grammar
Next Topic:higher-level access to model
Current Time: Fri Jul 25 23:43:51 EDT 2025
Powered by FUDForum. Page generated in 0.08649 seconds
