Home » Modeling » TMF (Xtext) » two grammar rules should be independent(but actually they aren't)
two grammar rules should be independent [message #872519] Wed, 16 May 2012 05:06 Go to next message
Hi Team,
this is a snip out of my code, that makes some kind of trouble.
action:
	typ=Event	|
	typ=Ex
Event hidden(UTS_COMMENT):
	type='event' WS ('-d'|'-e') WS ID+ WS*
Ex hidden(UTS_COMMENT):
	type='exit' (WS ('okay' | 'OKAY' | 'ERROR' | 'CRITERR' | 'TIMEOUT' | 'ABORT' | 'TRANS') WS* (value+=NEWmore_strings)?)?
This part should recognize the following as an example:
event -d TESTEVENT
exit	OKAY
exit 	ERROR
This works so far. But I get into trouble, if the ID in the "Event" rule contains one of the values from the multiple choice String out of the "Ex" Rule.
From my Point of view these two rules are totaly independent, but they aren't anyway.
The following example should also be 'good', but it isn't recognized as good:
event -d OKAY
exit	OKAY
event -d ERROR
exit ERROR
Eclipse tells me:
required (...)+ loop did not match anything at input 'OKAY'
So in my opinion the 'OKAY' is not recognized as an ID, but as a string from the Ex rule, but why.
Thanks in advance.
Re: two grammar rules should be independent [message #872528 is a reply to message #872519] Wed, 16 May 2012 05:20 Go to previous messageGo to next message
Hello, Tim!
What's happening is that all explicit strings you put into your grammar turn into keywords (including the 'e', if you implement doubles with scientific notation the way it's recommended, i.e. via datatype rules, so I made mine a terminal anyway).
I have the same problem with some of my grammar... I want to have a an identifier at a place in the grammar and then continue parsing down one path only if that identifier is a certain string, without it turning into a keyword, since the keyword can then not be used as an identifier in other places in the grammar. The reason in my cases is that I'm implementing an already designed DSL that's parsed in a more flexible framework elsewhere.
Anyway, I hope that at least helps you figure out what's going wrong. I'm afraid I don't have a solution for you, except this:
action:
	typ=Event	|
	typ=Ex
ExKeyword:
        key=('okay' | 'OKAY' | 'ERROR' | 'CRITERR' | 'TIMEOUT' | 'ABORT' | 'TRANS');
	type='event' WS ('-d'|'-e') WS (ID | ExKeyword)+ WS*
	type='exit' (WS ExKeyword WS* (value+=NEWmore_strings)?)?
(untested)
Re: two grammar rules should be independent [message #872533 is a reply to message #872528] Wed, 16 May 2012 05:31 Go to previous messageGo to next message
A question to the less newbie xtext hackers here:
Is there a way to solve this? I'm thinking something like....
FieldSection:
    section=ID '{'   ({ current.section=='special' =>} fields+=SpecialFields*)
                   | ({ current.section=='odd' =>} fields+=OddFields*)
                   | fields+=NormalFields*
Re: two grammar rules should be independent [message #872691 is a reply to message #872528] Wed, 16 May 2012 11:51 Go to previous message
On 2012-16-05 11:20, Mikael Karpberg wrote:
> Hello, Tim!
The standard solution would be to have a MyID that is ID | your keywords
and use that instead of ID.
MyID : ID | ExKeyword ;
You then need to take care of coloring of the ExKeywords when they are
used as identifiers.
> action:
> typ=Event |
> typ=Ex
> ExKeyword:
> 'TRANS');
Depending on the rest of the grammar the '-d' and '-e' may give you
problems. You could instead do '-' ID and validate that the ID is a 'd'
or an 'e'.
- henrik
Previous Topic:generation of an Xtext grammar
Next Topic:Validating unused declarations
Current Time: Sun Jul 27 23:02:28 EDT 2025
Powered by FUDForum. Page generated in 0.03859 seconds
