Home » Modeling » Papyrus » Plugin vs. stand alone version
icon5.gif  Plugin vs. stand alone version [message #871484] Mon, 14 May 2012 02:52 Go to next message
HI all,
please help to understand the differences between the Papyrus eclipse plug-in and the stand alone version. The plug-in has the version 0.8 but the stand alone version is 1.12.3.
Which one is newer and which of them is more recommended to use?
Konstantin
Re: Plugin vs. stand alone version [message #871994 is a reply to message #871484] Tue, 15 May 2012 05:04 Go to previous messageGo to next message
Hello Konstantin,
You should use Eclipse Indigo (3.7.2) + MDT Papyrus (0.8.2).
Camille
Re: Plugin vs. stand alone version [message #872595 is a reply to message #871994] Wed, 16 May 2012 08:19 Go to previous messageGo to next message
Hi Camille,
Are you proposing to use the development version 0.8.2?
Konstantin
Re: Plugin vs. stand alone version [message #872596 is a reply to message #872595] Wed, 16 May 2012 08:23 Go to previous messageGo to next message
Hello Konstantin,
The stand-alone version (1.12.x) is deprecated, and is 3 or 4 years-old. When Papyrus migrated to an Eclipse project, it had to downgrade its version number to match the Incubation constraint (Version < 1.0.0). 0.8.2 is actually the latest and most stable release of Papyrus (February 2012).
Camille
Re: Plugin vs. stand alone version [message #1220346 is a reply to message #871484] Wed, 11 December 2013 04:04 Go to previous message
Hello Konstantin,
if you need to generate code,
1) standalone has some templates for C & C++ but
1.1) these you must maintain yourself,
1.2) used acceleo version is an older one than what is current today, so old and awful jet-like template format is hard to follow
2) plugin version is an eclipse project, currently there is no code generation templates for papyrus plugin bundle.
If you'd like to generate documents from the models, as far as i know, this topic is not addressed in the plugin version.
I hope this helps. Smile
Furkan
Previous Topic:Component Diagrams - missing features
Next Topic:Creating Reports and Getting Information Out of a SysML Model
Current Time: Sat Jul 26 03:23:49 EDT 2025
Powered by FUDForum. Page generated in 0.35951 seconds
