Different EMF DataSoruce [message #872484] |
Wed, 16 May 2012 03:54  |
i want to print a SWT Table with a EMF Model. The EMF Model is stored in a xmi file. At runtime the user can choose the storage location for the xmi file.
1. Is a data source the stored xmi file or the ecore file?
If data source the xmi file(s):
2. How can i add this (different) data source in birt?
Is there a Tutorial for EMF and Birt?
[Updated on: Wed, 16 May 2012 04:06] by Moderator
Re: Different EMF DataSoruce [message #872757 is a reply to message #872709] |
Wed, 16 May 2012 14:55  |
Ed Merks wrote on Wed, 16 May 2012 12:42Comments below.
Which one exactly do you mean?
Iam confused, if i use a ecore file as datasource, then i can only select ecore types (EAttribute, EAnnotation, EClass ...)in a dataset.
If i use a stored xmi file, i cant't select anything, the list is empty.
FUDForum. Page generated in 0.05026 seconds
