Home » Archived » BIRT » Any way to set page break at render time?
Any way to set page break at render time? [message #872296] Tue, 15 May 2012 17:10 Go to next message
I'm using BIRT 2.5 with the runtime with a custom plugin for XLS that renders charts.
The report contains a crosstab and some charts. The issue is that when the chart is shown, and depending on the configuration, it else shows the charts streched or the crosstab garbled.
To resolve that issue my idea was to use a new sheet for charts.
On the otherside the report is executed first in HTML and then exported to XLS if the user desires so.
The issue arises that I don't want to paginate in HTML but I do want to paginate in XLS.
As the report's RunTask is executed only once and there are two different RenderTasks, I need the page break to be done only on the render time but when I do, I get:
"Page break can't be set at render time"
A solution would be to run again the query but the queries take 10 minutes so it's not an option for the user to wait for it do be done again.
So, is there another way to set the page break according to the report output?
Re: Any way to set page break at render time? [message #872720 is a reply to message #872296] Wed, 16 May 2012 13:19 Go to previous messageGo to next message
Using the web viewer I see that there are buttons to select which page to show... Is there any request parameter that I can use so it exports to single page?
Re: Any way to set page break at render time? [message #873136 is a reply to message #872720] Thu, 17 May 2012 11:09 Go to previous messageGo to next message
The issue is that pagination is determined at run time. I would look at
the original issue again. Can you post a screen shot of the garbled chart?
Jason
> to single page?
Re: Any way to set page break at render time? [message #873644 is a reply to message #872296] Fri, 18 May 2012 14:45 Go to previous messageGo to next message
Here is a screenshot..
I'm using the native xls plugin for adding the image to xls.
The crosstab contains seconds in an hour so that columns cannot be reduced.
The crosstab is shown this way as it's limited by the page size. So I increased the page size, but that makes the chart stretch also..
If I add the chart in a new page this problem is fixed but I would need to runandrender again..
  • Attachment: Untitled.png
    (Size: 89.11KB, Downloaded 307 times)
Re: Any way to set page break at render time? [message #882035 is a reply to message #873644] Tue, 05 June 2012 13:08 Go to previous message
Hallo Jonathan,
I'm just facing the same problem you had 3 years ago: I have tested my multy-side excel report, but it renders onto one page in the separate mode. Actually I have to use run-and-render-separately, because I need to create a toc on other reports (pdf). Ok, I could avoid the problem, by setting "rr-together" for excel and "r-separated-r" for pdf's. But I find it fool.
Perhabs you know the solution?
Thanks very much and
best regards
Denis
Previous Topic:Exporting Dynamic Images From BIRT
Next Topic:Bookmarks missing from PDF Reports
Current Time: Sun Jul 20 21:24:11 EDT 2025
Powered by FUDForum. Page generated in 0.09363 seconds
