MacOS X: CVS-SSH2 Plugin: ClassDefNotFound [message #87198] |
Wed, 20 August 2003 10:17  |
I've been attempting to use the SSH2 CVS Plugin [1] with Eclipse 3M2 under
MacOS 10.2.6 using
the Apple JDK 1.4.1. I'm able to create a CVS connection using extssh2,
but when I try to share a
project into a repository I'm seeing the following in .log:
java.lang.NoClassDefFoundError: javax/crypto/spec/SecretKeySpec
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:115)
at com.jcraft.jsch.Identity.<init>(Unknown Source)
at com.jcraft.jsch.JSch.addIdentity(Unknown Source)
at com.jcraft.eclipse.cvsssh2.CVSSSH2ServerConnection.open(Unkn own
Sourc
e)
at
org.eclipse.team.internal.ccvs.core.connection.Connection.op en(Connec
tion.java:134) [...]
Has anyone found a way to get this working?
I dropped in version 0.1.6 of the jsch [2] dependency, and it seemed to
make little difference.
However, it was positive to note that the examples that come with jsch did
run for me under
MacOS X (the ones I tried).
I also tried adding jce.jar to the libraries used by the Eclipse Java
runtime (Windows/Preferences/
Java/Installed JREs), but again this produced no difference.
All clues greatly appreciated...
Richard
1. http://www.jcraft.com/eclipse-cvsssh2/
2 http://www.jcraft.com/jsch/index.html
Re: MacOS X: CVS-SSH2 Plugin: ClassDefNotFound [message #99594 is a reply to message #91848] |
Mon, 29 September 2003 06:45  |
Originally posted by: Andre_Weinand.oti.com
On 3.9.2003 17:19 Uhr, in article bj50qu$o7h$1@eclipse.org, "ymnk"
<ymnk@jcraft.com> wrote:
> I'm an author of this plug-in.
>> MacOS 10.2.6 using
> I guess that Eclipse is still running on JDK 1.3.
> I'm not an OS X user, but many OS X users had reported similar problem
> and one of them kindly taught me he could fix that problem by switching
> JDK version. Here is a quote from his howto.
> What you have to do is go into "Eclipse.app", and then into "Contents",
> and then edit "Info.plist". This is an XML property file, and there
> will be an entry (near the top for me) like
> <key>JVMVersion</key>
> <string>1.3.1</string>
> Replace the "1.3.1" with whatever version you're actually using
> ("1.4.1" in my case) and things work a _lot_ better...
No, the Info.plist file for Eclipse uses the standard Eclipse command line
argument syntax, so the above guess would not work.
- Eclipse 3.0 > M1 uses 1.4.1 automatically if its available,
- for 2.1 versions you can force Eclipse to use the 1.4.1 via
<string>-XXvm=1.4.1</string>,
- to check what version Eclipse runs on just do a
Help > About Eclipse Platform > Configuration Details
--andre
FUDForum. Page generated in 0.05736 seconds
