Home » Modeling » EMF » [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000
| [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #870231] |
Mon, 07 May 2012 07:14  |
I am getting the above error message when trying to persist a graphiti Diagram object.
I am not sure about this, but I think the sql mapper adds a constraint to the table in question "FOREIGN KEY SAME TABLE" which leads to this error message...
The constraint will be re-generated the next time the cdo server is started (if I drop the constraint)...
Any hints?
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #870238 is a reply to message #870233] |
Mon, 07 May 2012 08:16   |
Hi Erdal,
Teneo will generate readable fk constraint names, this could in some special cases maybe result in name clashes (not
sure), in any case you can try to set this property/option to false:
teneo.naming.set_foreign_key_name
this should hopefully help.
If it doesn't can you post the generated hbm, or more specifically the part which defines the fk constraint? Is it maybe
generated twice?
gr. Martin
On 05/07/2012 01:46 PM, Erdal Karaca wrote:
> In case you would like to have a hint for further research:
> EClass StyleContainer
> - styles : Style 0..*
> EClass Style implements StyleContainer
> So, adding the "FOREIGN KEY SAME TABLE" constraint does make sense, but in this case conflicts...
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #870244 is a reply to message #870238] |
Mon, 07 May 2012 08:36   |
Thanks, Martin!
Setting the key to false helped!
Martin taal wrote on Mon, 07 May 2012 08:16Hi Erdal,
generated twice?
gr. Martin
The Netherlands
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #870431 is a reply to message #870413] |
Tue, 08 May 2012 03:10   |
You can find the mapping by debugging into this method: TeneoHibernateMappingProvider.generateMapping
Or another way is generating it directly using a few lines of java, see this testcase for an example:
http://git.eclipse.org/c/cdo/cdo.git/tree/plugins/org.eclipse.emf.cdo.examples.hibernate.client/src/org/eclipse/emf/cdo/examples/hibernate/client/GenerateHBMTest.java
gr. Martin
On 05/08/2012 07:27 AM, Erdal Karaca wrote:
> Martin, unfortunately, the problem still occurs... How can I get the generated hbm.xml?
> Or where do I find it?
> Though, this time, there are more foreign keys generated than not setting the key...
The Netherlands
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #870439 is a reply to message #870434] |
Tue, 08 May 2012 04:35   |
Hmm, I can get to the configuration object, but how to dump it to a xml file, you have any idea?
gr. Martin
On 05/08/2012 09:51 AM, Erdal Karaca wrote:
> Is there a way to dump the hibernate Configuration object
> (org.eclipse.emf.cdo.server.hibernate.IHibernateStore.getHibernateConfiguration()) to an xml file? that seems to contain
> all relevant data... Then, we could provide a new cdo command to export the hbm mapping or configuration file...
The Netherlands
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #870442 is a reply to message #870238] |
Tue, 08 May 2012 05:11   |
So, I have exported the generated hbm file... What do I have to look for? I am not familiar with hibernate...
Though, this is the table/Class with fk conflicts:
<class entity-name="StyleContainer" abstract="true" lazy="true" discriminator-value="StyleContainer" table="`stylecontainer`">
<meta attribute="eclassName">StyleContainer</meta>
<meta attribute="epackage">http://eclipse.org/graphiti/mm</meta>
<tuplizer entity-mode="pojo" class="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORevisionTuplizer"/>
<tuplizer entity-mode="dynamic-map" class="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORevisionTuplizer"/>
<id type="long" name="idcol" column="idcol" access="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOSyntheticIdPropertyHandler">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<discriminator type="string">
<column name="dtype" index="stylecontainerdtype" length="255" not-null="true"/>
</discriminator>
<property name="resourceID" type="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOIDUserType">
<column name="resource_id"/>
</property>
<property name="containerID" type="string">
<column name="container_id"/>
</property>
<property name="cdo_teneo_e_version" type="java.lang.Integer">
<meta attribute="version">true</meta>
<column name="e_version"/>
</property>
<property name="commit_TimeStamp" type="java.lang.Long"/>
<bag name="styles" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`style_stylecontainer_e_id`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="Style"/>
</bag>
</class>
generated twice?
gr. Martin
The Netherlands
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #870451 is a reply to message #870442] |
Tue, 08 May 2012 05:53   |
Hmm, I don't see unique constraint or something, I think the next step is to find out what constraint fails and on what
database columns it fails. Maybe this is present somewhere in the database log. Another thing can be to debug inside the
hibernate code, often a sql BatchUpdateException is thrown which has the underlying exception in a separate member, so
the real exception is not displayed in the stack trace.
gr. Martin
> </id>
> </discriminator>
> </property>
> </property>
> </property>
> <key update="true">
> </key>
> </bag>
> </class>
>> Hi Erdal,
>> maybe generated twice?
>> gr. Martin
>> The Netherlands
The Netherlands
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #870485 is a reply to message #870451] |
Tue, 08 May 2012 08:07   |
This is the insert which is being executed...
Hibernate: insert into [stylecontainer] (resource_id, container_id, e_version, commit_TimeStamp, [color_background_e_id], [color_foreground_e_id], [linewidth], [linestyle], [filled], [linevisible], [renderingstyle_renderingstyle_e_id], [transparency], [id], [description], [font_font_e_id], [horizontalalignment], [verticalalignment], [angle], [stretchh], [stretchv], [proportional], [style_stylecontainer_e_id], dtype) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, 'Style')
fields parameter of org.hibernate.persister.entity.AbstractEntityPersister.insert(Object[], boolean[], String, Object, SessionImplementor):
[NULL, lhttp://eclipse.org/graphiti/mm/pictograms#Diagram#2_:_styleContainer, 1, 1336477583737, org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.HibernateMoveableListWrapper@52d37e, null, null, 2, SOLID, null, true, null, 0.0, COMMON-VALUES, null, null, UNSPECIFIED, UNSPECIFIED, null, null, null, null, Diagram@OID:http://eclipse.org/graphiti/mm/pictograms#Diagram#2:0v1]
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #870511 is a reply to message #870485] |
Tue, 08 May 2012 09:43   |
Okay and what constraint fails? A not-null, a unique or a fk constraint?
and on what field/column?
gr. Martin
The Netherlands
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #871535 is a reply to message #871514] |
Mon, 14 May 2012 07:06   |
When using the JOINED inheritance mapping, I will get this hibernate mapping:
<joined-subclass entity-name="Style" abstract="false" lazy="true" extends="StyleContainer" table="`style`">
<meta attribute="eclassName">Style</meta>
<meta attribute="epackage">http://eclipse.org/graphiti/mm/algorithms/styles</meta>
<key>
<column name="`stylecontainer_e_id`"/>
</key>
<many-to-one name="background" entity-name="Color" lazy="false" cascade="merge,persist,save-update,lock,refresh" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`color_background_e_id`"/>
</many-to-one>
<many-to-one name="foreground" entity-name="Color" lazy="false" cascade="merge,persist,save-update,lock,refresh" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`color_foreground_e_id`"/>
</many-to-one>
<property name="lineWidth" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Integer">
<column not-null="false" unique="false" name="`linewidth`"/>
</property>
<property name="lineStyle" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`linestyle`"/>
<type name="org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOENumStringType">
<param name="eclassifier">LineStyle</param>
<param name="epackage">http://eclipse.org/graphiti/mm/algorithms/styles</param>
</type>
</property>
<property name="filled" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Boolean">
<column not-null="false" unique="false" name="`filled`"/>
</property>
<property name="lineVisible" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Boolean">
<column not-null="false" unique="false" name="`linevisible`"/>
</property>
<many-to-one name="renderingStyle" entity-name="RenderingStyle" lazy="false" cascade="all" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`renderingstyle_renderingstyle_e_id`"/>
</many-to-one>
<property name="transparency" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Double">
<column not-null="false" unique="false" name="`transparency`"/>
</property>
<property name="id" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="`id`"/>
</property>
<property name="description" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`description`"/>
</property>
<many-to-one name="font" entity-name="Font" lazy="false" cascade="merge,persist,save-update,lock,refresh" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`font_font_e_id`"/>
</many-to-one>
<property name="horizontalAlignment" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`horizontalalignment`"/>
<param name="eclassifier">Orientation</param>
</type>
</property>
<property name="verticalAlignment" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`verticalalignment`"/>
</type>
</property>
<property name="angle" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Integer">
<column not-null="false" unique="false" name="`angle`"/>
</property>
<property name="stretchH" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Boolean">
<column not-null="false" unique="false" name="`stretchh`"/>
</property>
<property name="stretchV" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Boolean">
<column not-null="false" unique="false" name="`stretchv`"/>
</property>
<property name="proportional" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Boolean">
<column not-null="false" unique="false" name="`proportional`"/>
</property>
<many-to-one name="styleContainer" entity-name="StyleContainer" lazy="false" cascade="merge,persist,save-update,lock,refresh" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`style_stylecontainer_e_id`"/>
</many-to-one>
</joined-subclass>
I dont see any instructions to create foreign keys... but having a look at the databse table structure, there are 7 foreign key constraints for the table "style"...
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #871542 is a reply to message #871535] |
Mon, 14 May 2012 07:15   |
Hi Erdal,
That's a pity that did not help, to give more input from my side I would need to know what foreign key constraints on
what fields and what values they fail.
gr. Martin
> <key>
> </key>
> </many-to-one>
> </many-to-one>
> </property>
> </type>
> </property>
> </property>
> </property>
> not-null="false">
> </many-to-one>
> </property>
> </property>
> </property>
> </many-to-one>
> </type>
> </property>
> </type>
> </property>
> </property>
> </property>
> </property>
> </property>
> </many-to-one>
> </joined-subclass>
The Netherlands
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #871912 is a reply to message #871542] |
Tue, 15 May 2012 02:08   |
This sql is executed...
Hibernate: insert into [style] ([color_background_e_id], [color_foreground_e_id], [linewidth], [linestyle], [filled], [linevisible], [renderingstyle_renderingstyle_e_id], [transparency], [id], [description], [font_font_e_id], [horizontalalignment], [verticalalignment], [angle], [stretchh], [stretchv], [proportional], [style_stylecontainer_e_id], [stylecontainer_e_id]) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
Error message:
java.sql.SQLException: Die INSERT-Anweisung steht in Konflikt mit der FOREIGN KEY-Einschränkung 'FK68B1DB139541E86'. Der Konflikt trat in der '_TEST'-Datenbank, Tabelle 'dbo.stylecontainer', column 'idcol' auf.
at net.sourceforge.jtds.jdbc.SQLDiagnostic.addDiagnostic(SQLDiagnostic.java:368)
at net.sourceforge.jtds.jdbc.TdsCore.tdsErrorToken(TdsCore.java:2820)
at net.sourceforge.jtds.jdbc.TdsCore.nextToken(TdsCore.java:2258)
at net.sourceforge.jtds.jdbc.TdsCore.getMoreResults(TdsCore.java:632)
I am not sure, but I think when the row is inserted the db checks whether the row already exists as it has a foreign key check to itself...
This is the table that is generated for the Style EClass...
CREATE TABLE [dbo].[style](
[stylecontainer_e_id] [numeric](19, 0) NOT NULL,
[color_background_e_id] [numeric](19, 0) NULL,
[color_foreground_e_id] [numeric](19, 0) NULL,
[linewidth] [int] NULL,
[linestyle] [varchar](255) NULL,
[filled] [tinyint] NULL,
[linevisible] [tinyint] NULL,
[renderingstyle_renderingstyle_e_id] [numeric](19, 0) NULL,
[transparency] [float] NULL,
[id] [varchar](255) NOT NULL,
[description] [varchar](255) NULL,
[font_font_e_id] [numeric](19, 0) NULL,
[horizontalalignment] [varchar](255) NULL,
[verticalalignment] [varchar](255) NULL,
[angle] [int] NULL,
[stretchh] [tinyint] NULL,
[stretchv] [tinyint] NULL,
[proportional] [tinyint] NULL,
[style_stylecontainer_e_id] [numeric](19, 0) NULL,
PRIMARY KEY CLUSTERED
[stylecontainer_e_id] ASC
)WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
) ON [PRIMARY]
GO
SET ANSI_PADDING OFF
GO
ALTER TABLE [dbo].[style] WITH CHECK ADD CONSTRAINT [FK68B1DB139541E86] FOREIGN KEY([style_stylecontainer_e_id])
REFERENCES [dbo].[stylecontainer] ([idcol])
GO
ALTER TABLE [dbo].[style] CHECK CONSTRAINT [FK68B1DB139541E86]
GO
ALTER TABLE [dbo].[style] WITH CHECK ADD CONSTRAINT [FK68B1DB1405D6A0D] FOREIGN KEY([color_background_e_id])
REFERENCES [dbo].[color] ([idcol])
GO
ALTER TABLE [dbo].[style] CHECK CONSTRAINT [FK68B1DB1405D6A0D]
GO
ALTER TABLE [dbo].[style] WITH CHECK ADD CONSTRAINT [FK68B1DB17AB711A4] FOREIGN KEY([font_font_e_id])
REFERENCES [dbo].[font] ([idcol])
GO
ALTER TABLE [dbo].[style] CHECK CONSTRAINT [FK68B1DB17AB711A4]
GO
ALTER TABLE [dbo].[style] WITH CHECK ADD CONSTRAINT [FK68B1DB17D893549] FOREIGN KEY([style_stylecontainer_e_id])
REFERENCES [dbo].[diagram] ([containershape_e_id])
GO
ALTER TABLE [dbo].[style] CHECK CONSTRAINT [FK68B1DB17D893549]
GO
ALTER TABLE [dbo].[style] WITH CHECK ADD CONSTRAINT [FK68B1DB1CD6F9B18] FOREIGN KEY([color_foreground_e_id])
GO
ALTER TABLE [dbo].[style] CHECK CONSTRAINT [FK68B1DB1CD6F9B18]
GO
ALTER TABLE [dbo].[style] WITH CHECK ADD CONSTRAINT [FK68B1DB1E7A93614] FOREIGN KEY([stylecontainer_e_id])
GO
ALTER TABLE [dbo].[style] CHECK CONSTRAINT [FK68B1DB1E7A93614]
GO
ALTER TABLE [dbo].[style] WITH CHECK ADD CONSTRAINT [FK68B1DB1F1E869A] FOREIGN KEY([renderingstyle_renderingstyle_e_id])
REFERENCES [dbo].[renderingstyle] ([idcol])
GO
ALTER TABLE [dbo].[style] CHECK CONSTRAINT [FK68B1DB1F1E869A]
GO
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #871953 is a reply to message #871912] |
Tue, 15 May 2012 03:47   |
Hi Erdal,
It seems that the parent object, the stylecontainer is not being saved/inserted before the style, can you check that?
gr. Martin
> Error message:
> check to itself...
> [angle] [int] NULL,
> PRIMARY KEY CLUSTERED (
> ON [PRIMARY]
> ) ON [PRIMARY]
> GO
> GO
> GO
> GO
> GO
> GO
> GO
> GO
> GO
> GO
> GO
> GO
> GO
> GO
> GO
> GO
The Netherlands
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #871969 is a reply to message #871956] |
Tue, 15 May 2012 04:26   |
This is the ouput of the log on server side:
Hibernate: insert into [stylecontainer] (resource_id, container_id, e_version, commit_TimeStamp) values (?, ?, ?, ?)
2012-05-15 10:22:04.512 DEBUG [Thread-7 ] (IdentifierGeneratorHelper.java:87) - Natively generated identity: 1
2012-05-15 10:22:04.512 DEBUG [Thread-7 ] (AbstractBatcher.java:418) - about to close PreparedStatement (open PreparedStatements: 1, globally: 1)
2012-05-15 10:22:04.512 DEBUG [Thread-7 ] (AbstractBatcher.java:410) - about to open PreparedStatement (open PreparedStatements: 0, globally: 0)
2012-05-15 10:22:04.512 DEBUG [Thread-7 ] (SQLStatementLogger.java:111) - insert into [style] ([color_background_e_id], [color_foreground_e_id], [linewidth], [linestyle], [filled], [linevisible], [renderingstyle_renderingstyle_e_id], [transparency], [id], [description], [font_font_e_id], [horizontalalignment], [verticalalignment], [angle], [stretchh], [stretchv], [proportional], [style_stylecontainer_e_id], [stylecontainer_e_id]) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
2012-05-15 10:22:04.543 DEBUG [Thread-7 ] (AbstractBatcher.java:418) - about to close PreparedStatement (open PreparedStatements: 1, globally: 1)
2012-05-15 10:22:04.559 DEBUG [Thread-7 ] (JDBCExceptionReporter.java:225) - could not insert: [Style] [insert into [style] ([color_background_e_id], [color_foreground_e_id], [linewidth], [linestyle], [filled], [linevisible], [renderingstyle_renderingstyle_e_id], [transparency], [id], [description], [font_font_e_id], [horizontalalignment], [verticalalignment], [angle], [stretchh], [stretchv], [proportional], [style_stylecontainer_e_id], [stylecontainer_e_id]) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
And, this is after removal of all fk constraints of Style...
2012-05-15 10:14:43.065 DEBUG [Thread-7 ] (AbstractBatcher.java:410) - about to open PreparedStatement (open PreparedStatements: 0, globally: 0)
2012-05-15 10:14:43.065 DEBUG [Thread-7 ] (SQLStatementLogger.java:111) - insert into [stylecontainer] (resource_id, container_id, e_version, commit_TimeStamp) values (?, ?, ?, ?)
2012-05-15 10:14:43.080 DEBUG [Thread-7 ] (IdentifierGeneratorHelper.java:87) - Natively generated identity: 1
2012-05-15 10:14:43.080 DEBUG [Thread-7 ] (AbstractBatcher.java:418) - about to close PreparedStatement (open PreparedStatements: 1, globally: 1)
2012-05-15 10:14:43.080 DEBUG [Thread-7 ] (AbstractBatcher.java:410) - about to open PreparedStatement (open PreparedStatements: 0, globally: 0)
2012-05-15 10:14:43.080 DEBUG [Thread-7 ] (SQLStatementLogger.java:111) - insert into [style] ([color_background_e_id], [color_foreground_e_id], [linewidth], [linestyle], [filled], [linevisible], [renderingstyle_renderingstyle_e_id], [transparency], [id], [description], [font_font_e_id], [horizontalalignment], [verticalalignment], [angle], [stretchh], [stretchv], [proportional], [style_stylecontainer_e_id], [stylecontainer_e_id]) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
2012-05-15 10:14:43.080 DEBUG [Thread-7 ] (AbstractSaveEventListener.java:319) - executing identity-insert immediately
Does that mean that Style must be inserted before StyleContainer?
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #872021 is a reply to message #871969] |
Tue, 15 May 2012 06:16   |
Hi Erdal,
For the FK constraint mentioned in the error (FK68B1DB139541E86 note id may change in re-installs..) can you check/post
what the source and target columns are?
gr. Martin
The Netherlands
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #874585 is a reply to message #872089] |
Mon, 21 May 2012 03:36   |
This ist the location I debugged:
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(InternalCommitContext, OMMonitor)
final List<InternalCDORevision> repairContainerIDs = new ArrayList<InternalCDORevision>();
final List<InternalCDORevision> repairResourceIDs = new ArrayList<InternalCDORevision>();
for (InternalCDORevision revision : context.getNewObjects())
// keep track for which cdoRevisions the container id needs to be repaired afterwards
final CDOID containerID = (CDOID)revision.getContainerID();
if (containerID instanceof CDOIDTemp && !containerID.isNull())
repairContainerIDs.add(revision);
final CDOID resourceID = revision.getResourceID();
if (resourceID instanceof CDOIDTemp && !resourceID.isNull())
repairResourceIDs.add(revision);
final String entityName = getStore().getEntityName(revision.getEClass());
session.saveOrUpdate(entityName, revision);
The second iteration of the for-loop will saveOrUpdate an entity with the name "ContainerShape" and fails in the flow of that call.
(First call is a regular business object not specific to graphiti and succeeds.)
It fails when trying to execute this:
The hibernate mapping contains this (using JOINED inheritance mode):
<joined-subclass entity-name="ContainerShape" abstract="false" lazy="true" extends="Shape" table="`containershape`">
<meta attribute="eclassName">ContainerShape</meta>
<meta attribute="epackage">http://eclipse.org/graphiti/mm/pictograms</meta>
<key>
<column name="`shape_e_id`"/>
</key>
<bag name="children" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`shape_container_e_id`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="Shape"/>
</bag>
</joined-subclass>
<joined-subclass entity-name="Shape" abstract="false" lazy="true" extends="AnchorContainer" table="`shape`">
<meta attribute="eclassName">Shape</meta>
<key>
<column name="`anchorcontainer_e_id`"/>
</key>
<many-to-one name="container" entity-name="ContainerShape" lazy="false" cascade="merge,persist,save-update,lock,refresh" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`shape_container_e_id`"/>
</many-to-one>
</joined-subclass>
<joined-subclass entity-name="AnchorContainer" abstract="true" lazy="true" extends="PictogramElement" table="`anchorcontainer`">
<meta attribute="eclassName">AnchorContainer</meta>
<key>
<column name="`pictogramelement_e_id`"/>
</key>
<bag name="anchors" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`anchor_parent_e_id`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="Anchor"/>
</bag>
</joined-subclass>
<joined-subclass entity-name="PictogramElement" abstract="true" lazy="true" extends="GraphicsAlgorithmContainer" table="`pictogramelement`">
<meta attribute="eclassName">PictogramElement</meta>
<key>
<column name="`graphicsalgorithmcontainer_e_id`"/>
</key>
<property name="visible" lazy="false" insert="true" update="true" not-null="true" unique="false" type="boolean">
<column not-null="true" unique="false" name="`visible`"/>
</property>
<many-to-one name="graphicsAlgorithm" entity-name="GraphicsAlgorithm" cascade="all" not-null="false" lazy="false" insert="true" update="true"/>
<property name="active" lazy="false" insert="true" update="true" not-null="true" unique="false" type="boolean">
<column not-null="true" unique="false" name="`active`"/>
</property>
<many-to-one name="link" entity-name="PictogramLink" cascade="all" not-null="false" lazy="false" insert="true" update="true"/>
</joined-subclass>
<joined-subclass entity-name="GraphicsAlgorithmContainer" abstract="true" lazy="true" extends="PropertyContainer" table="`graphicsalgorithmcontainer`">
<meta attribute="eclassName">GraphicsAlgorithmContainer</meta>
<key>
<column name="`propertycontainer_e_id`"/>
</key>
</joined-subclass>
<class entity-name="PropertyContainer" abstract="true" lazy="true" table="`propertycontainer`">
<meta attribute="eclassName">PropertyContainer</meta>
</id>
</property>
</property>
</property>
<bag name="properties" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`propertycontainer_properties_e_id`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="Property"/>
</bag>
</class>
I have attached an image of the type hierarchy of the Diagram EClass of graphiti...
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #881404 is a reply to message #881389] |
Mon, 04 June 2012 09:34   |
You can annotated EClasses and efeatures with the @Transient annotation, if an EClass has this annotation then all
associations pointing to this eclass will be transient (not mapped).
gr. Martin
On 06/04/2012 03:00 PM, Erdal Karaca wrote:
> If the former is not possible, how would ignoring associations look like in the annotations file?
> Martin taal wrote on Mon, 04 June 2012 08:52
>> Hi Erdal,
>> Preventing only the FK Constraints from being generated is not possible. Or do you mean to completely ignore the
>> association so that it is not mapped/managed by Hibernate?
>> gr. Martin
The Netherlands
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #881740 is a reply to message #881736] |
Tue, 05 June 2012 03:18   |
Hi Erdal,
Hopefully sometime today I will have time to look at it.
gr. Martin
On 06/05/2012 09:14 AM, Erdal Karaca wrote:
> Martin,
> I have saved the graphiti Diagram to a XMI file, see attachments.
> I started the server (which is downloadable from the CDO downloads page) and the CDO explorer (cdo downloads page).
> Then, I registered the graphiti ecore file from file system (for your convenience, see attachments) and imported the xmi file resource and saved...
> Everything worked without errors.
> Note: the downloaded CDO server uses a h2 store.
> If you use hibernate to store the XMI file, I assume you will be getting the errors.
> If you have a properly set up hibernate server, you could test to import the xmi file...
> Thanks!
The Netherlands
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #910673 is a reply to message #909318] |
Mon, 10 September 2012 03:41   |
Martin,
Just tested on mysql and cdo 4.1 and I am getting this error (no modifications to the attached files test.graphiti and graphiti.ecore):
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException: Cannot add or update a child row: a foreign key constraint fails (`repo1`.`style`, CONSTRAINT `style_stylecontainer` FOREIGN KEY (`style_stylecontainer_e_id`) REFERENCES `stylecontainer` (`idcol`))
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:406)
at com.mysql.jdbc.Util.getInstance(Util.java:381)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1038)
Maybe, my settings are wrong?
<property name="teneo.mapping.inheritance" value="JOINED"/>
<property name="teneo.mapping.always_map_list_as_bag" value="true"/>
<property name="teneo.mapping.join_table_for_non_contained_associations" value="false"/>
<property name="teneo.mapping.cascade_policy_on_non_containment" value="MERGE,PERSIST,REFRESH"/>
<property name="hibernate.hbm2ddl.auto" value="update"/>
<property name="hibernate.show_sql" value="true"/>
<property name="hibernate.connection.pool_size" value="10"/>
<property name="hibernate.cache.provider_class" value="org.hibernate.cache.HashtableCacheProvider"/>
<property name="hibernate.transaction.factory_class" value="org.hibernate.transaction.JDBCTransactionFactory"/>
<property name="hibernate.dialect" value="org.hibernate.dialect.MySQLDialect"/>
<property name="hibernate.connection.driver_class" value="com.mysql.jdbc.Driver"/>
<property name="hibernate.connection.url" value="jdbc:mysql://localhost:3306/repo1"/>
<property name="hibernate.connection.username" value="root"/>
<property name="hibernate.connection.password" value="root"/>
<property name="teneo.mapping.cascade_policy_on_containment" value="merge,persist,save-update,lock,refresh" />
<property name="teneo.naming.version_column" value="e_version"/>
<store type="hibernate">
<mappingProvider type="teneo">
</mappingProvider>
</store>
| Re: [CDO/Hibernate/SQLServer] SQL Error: 547, SQLState: 23000 [message #910700 is a reply to message #910673] |
Mon, 10 September 2012 04:33  |
Hi Erdal,
Your settings are not wrong, but they are different than what I tested. I will try with your settings.
gr. Martin
On 09/10/2012 09:41 AM, Erdal Karaca wrote:
> Martin,
> graphiti.ecore):
> </mappingProvider>
> </store>
The Netherlands
Current Time: Fri Nov 07 11:56:06 EST 2025
Powered by FUDForum. Page generated in 0.12029 seconds
