| Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #870991] |
Thu, 10 May 2012 09:39  |
I could successfully bring my RCP application on e4 M6.
After it launched I continuously get the below exception message in the Console view.
Please help.
!ENTRY org.eclipse.e4.ui.workbench.renderers.swt 4 2 2012-05-10 18:47:32.237
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.renderers.swt".
!STACK 0
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.generateParameterizedCommand(HandledContributionItem.java:547)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.getToolTipText(HandledContributionItem.java:511)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.updateToolItem(HandledContributionItem.java:498)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.update(HandledContributionItem.java:443)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.update(HandledContributionItem.java:430)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$3.run(HandledContributionItem.java:197)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.updateItemEnablement(HandledContributionItem.java:223)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$ToolItemUpdateTimer.run(HandledContributionItem.java:129)
at org.eclipse.swt.widgets.Display.timerProc(Display.java:4120)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2326)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3176)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1015)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:909)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:85)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:580)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:535)
at com.novell.idm.rcp.DesignerApplication.start(DesignerApplication.java:118)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
[Updated on: Thu, 10 May 2012 09:40] by Moderator
FUDForum. Page generated in 0.07320 seconds
