| Exception on setInput() [message #87183] |
Wed, 02 July 2003 06:21  |
Originally posted by: scheglov_ke.nlmk.ru
I use JFace in standalone application. I use several TableViewer's
without problem, but in one TableViewer I receive following exception.
Is this bug, or I forgot something?
org.eclipse.core.internal.runtime.AssertionFailedException: assertion failed: The application has not been initialized.
at org.eclipse.core.internal.runtime.Assert.isTrue(Assert.java: 101)
at org.eclipse.core.internal.runtime.InternalPlatform.assertIni tialized(InternalPlatform.java:178)
at org.eclipse.core.internal.runtime.InternalPlatform.getPlugin Registry(InternalPlatform.java:397)
at org.eclipse.core.internal.runtime.InternalPlatform.getRuntim ePlugin(InternalPlatform.java:418)
at org.eclipse.core.internal.runtime.InternalPlatform.handleExc eption(InternalPlatform.java:429)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:869)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1271)
at org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:494)
at org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:431)
at org.eclipse.jface.viewers.StructuredViewer$7.run(StructuredV iewer.java:861)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:801)
at org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:859)
at org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:821)
at org.eclipse.jface.viewers.TableViewer.inputChanged(TableView er.java:398)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:238)
at org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:991)
at ru.nlmk.cvts.train.DocumentNewDialog.createDialogArea(Docume ntNewDialog.java:272)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java: 577)
at org.eclipse.jface.window.Window.create(Window.java:302)
at org.eclipse.jface.window.Window.open(Window.java:552)
at ru.nlmk.cvts.train.DocumentsDialog.handleEditDocument(Docume ntsDialog.java:136)
at ru.nlmk.cvts.train.DocumentsDialog.buttonPressed(DocumentsDi alog.java:120)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:423)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2034)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1741)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:583 )
at org.eclipse.jface.window.Window.open(Window.java:563)
at ru.nlmk.cvts.train.TrainEditDialog.handleDocs(TrainEditDialo g.java:757)
at ru.nlmk.cvts.train.TrainEditDialog$18.widgetSelected(TrainEd itDialog.java:730)
at ru.nlmk.cvts.train.Main.handleEditTrain(Main.java:232)
at ru.nlmk.cvts.train.Main$5.run(Main.java:653)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:456)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:403)
at org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionItem.java:397)
at org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java:72)
at ru.nlmk.cvts.train.Main.run(Main.java:753)
at ru.nlmk.cvts.train.Main.main(Main.java:1017)
SY, Konstantin.
| Re: Exception on setInput() [message #88705 is a reply to message #88570] |
Thu, 03 July 2003 23:16  |
John Arthorne <John_Arthorne@oti.com_> wrote:
> As you can see from the exception, running JFace in a stand-alone
> application is not supported. Either you'll need to manually rip out
Hm...
I found bug in my application - problem was, that _LabelProvider_ throws
ClassCastException. However as you can see, resulting exception was really
strange...
> the pieces of JFaces that depend on the platform, or wait for the rich
> client platform (minimal Eclipse) that is being developed for Eclipse 3.0.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=36967
SY, Konstantin.
FUDForum. Page generated in 0.03461 seconds
