org.eclipse.ajdt.javamodel.CompilationUnitFilter error on Eclipse startup [message #871597] |
Mon, 14 May 2012 09:51  |
I suddenly started getting the following error on startup:
The org.eclipse.jdt.ui.javaElementFilters plug-in extension "org.eclipse.ajdt.javamodel.CompilationUnitFilter" specifies a viewer filter class which does not exist.
Plug-in org.eclipse.ajdt.ui was unable to load class org.eclipse.ajdt.internal.ui.lazystart.CompilationUnitFilter.
Expected to find an object at table index: 1151
There's another error which also appears on startup:
The org.eclipse.jdt.ui.javaElementFilters plug-in extension "org.eclipse.pde.ui.ExternalPluginLibrariesFilter1" specifies a viewer filter class which does not exist.
Plug-in org.eclipse.pde.ui was unable to load class org.eclipse.pde.internal.ui.wizards.imports.ExternalPluginLibrariesFilter.
Does anybody know what might be wrong and how I can fix it?
The log contains things like:
!ENTRY org.eclipse.ui 4 4 2012-05-14 16:31:49.306
!MESSAGE Bad extension specification
!ENTRY com.adobe.flexbuilder.flashbridge 4 0 2012-05-14 16:31:49.306
!MESSAGE startup class must implement org.eclipse.ui.IStartup
!ENTRY org.eclipse.equinox.registry 4 1 2012-05-14 16:31:49.534
!MESSAGE Plug-in org.eclipse.ajdt.ui was unable to load class org.eclipse.ajdt.internal.ui.lazystart.AdviceImageDecorator.
!STACK 0
java.lang.IllegalStateException: Expected to find an object at table index: 1151
at org.eclipse.osgi.internal.resolver.StateReader.getFromObjectTable(StateReader.java:80)
at org.eclipse.osgi.internal.resolver.StateReader.readExportPackageDesc(StateReader.java:408)
at org.eclipse.osgi.internal.resolver.StateReader.readExportPackageDesc(StateReader.java:416)
at org.eclipse.osgi.internal.resolver.StateReader.readImportPackageSpec(StateReader.java:558)
at org.eclipse.osgi.internal.resolver.StateReader.readBundleDescriptionLazyData(StateReader.java:279)
at org.eclipse.osgi.internal.resolver.StateReader.fullyLoad(StateReader.java:801)
at org.eclipse.osgi.internal.resolver.BundleDescriptionImpl.loadLazyData(BundleDescriptionImpl.java:670)
at org.eclipse.osgi.internal.resolver.BundleDescriptionImpl.getResolvedRequires(BundleDescriptionImpl.java:234)
at org.eclipse.osgi.internal.loader.BundleLoader.<init>(BundleLoader.java:153)
at org.eclipse.osgi.internal.loader.BundleLoaderProxy.getBundleLoader0(BundleLoaderProxy.java:76)
at org.eclipse.osgi.internal.loader.BundleLoaderProxy.getBundleLoader(BundleLoaderProxy.java:60)
at org.eclipse.osgi.framework.internal.core.BundleHost.getBundleLoader(BundleHost.java:653)
at org.eclipse.osgi.framework.internal.core.BundleHost.checkLoader(BundleHost.java:199)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:226)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:268)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:53)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:264)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefinition$1.run(LightweightDecoratorDefinition.java:124)
at org.eclipse.core.runtime.Platform.run(Platform.java:889)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefinition.internalGetDecorator(LightweightDecoratorDefinition.java:120)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefinition.decorate(LightweightDecoratorDefinition.java:252)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager$LightweightRunnable.run(LightweightDecoratorManager.java:81)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.decorate(LightweightDecoratorManager.java:366)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.getDecorations(LightweightDecoratorManager.java:347)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.ensureResultCached(DecorationScheduler.java:370)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.run(DecorationScheduler.java:330)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!ENTRY org.eclipse.equinox.registry 4 1 2012-05-14 16:31:49.550
!MESSAGE Plug-in org.springframework.ide.eclipse.beans.ui was unable to load class org.springframework.ide.eclipse.beans.ui.model.BeansModelLabelDecorator.
!STACK 0
java.lang.IllegalStateException: Expected to find an object at table index: 1152
!ENTRY org.eclipse.equinox.registry 4 1 2012-05-14 16:31:49.741
!MESSAGE Plug-in org.springframework.ide.eclipse.webflow.ui was unable to load class org.springframework.ide.eclipse.webflow.ui.model.WebflowModelLabelDecorator.
!STACK 0
I'm using:
SpringSource Tool Suite
Version: 2.9.1.RELEASE
Build Id: 201203221000
FUDForum. Page generated in 0.04007 seconds
