Home » Modeling » TMF (Xtext) » [Xtext 2.3.0M7] org.hamcrest in the test plugin
[Xtext 2.3.0M7] org.hamcrest in the test plugin [message #871416] Sun, 13 May 2012 10:55 Go to next message
I noted that re-running the workflow for a language with Xtext 2.3 M7
org.hamcrest is added to the tests plugin as an imported package... but
is it used somewhere?
cheers
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #871423 is a reply to message #871416] Sun, 13 May 2012 11:42 Go to previous messageGo to next message
i guess this dep is redunant since junit4 already requires the bundle org.hamcrest.core. (so dont care)
~Christian
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #871456 is a reply to message #871423] Sun, 13 May 2012 16:35 Go to previous messageGo to next message
Am 13.05.12 17:42, schrieb Christian Dietrich:
> ~Christian
It's a PDE thing. Transitive package imports are not properly resolved
if you launch a test as a plain JUnit test thus you have to import
harmcrest explicitly.
Sebastian
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #871458 is a reply to message #871456] Sun, 13 May 2012 17:06 Go to previous messageGo to next message
>> Hi,
>> ~Christian
but who is using harmcrest internally? I'm asking because by removing
that import the tests run anyway...
if those imports are left in the MANIFEST, then building with tycho
complains about not being able to resolve them...
I managed to build the test plugin (importing harmcrest) with tycho only
by adding swtbot (which I know provides harmcrest) in the p2 repositories...
cheers
Lorenzo
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #871462 is a reply to message #871458] Sun, 13 May 2012 17:53 Go to previous messageGo to next message
there are some assertions within junit that use it.
~Christian
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #871501 is a reply to message #871462] Mon, 14 May 2012 05:11 Go to previous messageGo to next message
On 05/13/2012 11:53 PM, Christian Dietrich wrote:
> ~Christian
but then who provides org.hamcrest? I'm asking because, as I said in my
previous post, if I don't include the swtbot update site (which I'm not
using in my DSL) tycho fails to resolve and install org.hamcrest...
cheers
Lorenzo
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #871504 is a reply to message #871501] Mon, 14 May 2012 05:25 Go to previous messageGo to next message
Hi isn't the package contained in the org.hamcrest.core plugin?
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #871506 is a reply to message #871504] Mon, 14 May 2012 05:37 Go to previous messageGo to next message
actually I meant: which p2 repository/update site provides that plugin
(besides swtbot)?
Lorenzo
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #871508 is a reply to message #871506] Mon, 14 May 2012 05:41 Go to previous messageGo to next message
Am 14.05.12 11:37, schrieb Lorenzo Bettini:
> Hi
> (besides swtbot)?
> Lorenzo
It should be available from the orbit update site.
Sebastian
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #871519 is a reply to message #871508] Mon, 14 May 2012 06:09 Go to previous messageGo to next message
>> Hi
>> (besides swtbot)?
>> Lorenzo
thus it is not available from the eclipse update site, nor from the
xtext update site?
Lorenzo
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #871532 is a reply to message #871519] Mon, 14 May 2012 06:56 Go to previous messageGo to next message
Lorenzo,
the orbit repo is hosted at Eclipse:
http://download.eclipse.org/tools/orbit/downloads/
Sebastian
Am 14.05.12 12:09, schrieb Lorenzo Bettini:
>>> Hi
>>> (besides swtbot)?
>>> Lorenzo
> xtext update site?
> Lorenzo
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #873004 is a reply to message #871458] Thu, 17 May 2012 05:41 Go to previous messageGo to next message
I managed to solve the problem of building with tycho in the presence of
the generated dependencies on org.hamcrest as follows:
- in the tycho pom file I add this repository (so there's no need of
using the swtbot repository):
<repository>
<id>orbit</id>
<layout>p2</layout>
<url>http://download.eclipse.org/tools/orbit/downloads/drops/R20110523182458/repository/</url>
</repository>
- this however is not enough... I don't know whether it is a tycho
thing, but it cannot resolve org.hamcrest (and download it) if it is
just an imported package: I have to add org.hamcrest as a required
bundle in the MANIFEST.MF, thus
Require-Bundle: ...
org.eclipse.core.runtime,
org.eclipse.xtext.junit4,
org.junit4,
org.eclipse.ui.workbench;resolution:=optional,
org.eclipse.xtext.xbase.junit;bundle-version="2.3.0",
org.eclipse.xtext.xbase;bundle-version="2.3.0",
org.eclipse.jdt.core;bundle-version="3.7.3",
org.hamcrest <---------- MANUALLY ADDED
Import-Package: org.apache.commons.logging,
org.apache.log4j,
org.junit;version="4.5.0",
org.junit.runner;version="4.5.0",
org.junit.runner.manipulation;version="4.5.0",
org.junit.runner.notification;version="4.5.0",
org.junit.runners;version="4.5.0",
org.junit.runners.model;version="4.5.0",
org.hamcrest,
org.hamcrest.core
is this a bug? would it do harm to generate in the MANIFEST.MF of the
test plugin also org.hamcrest as required bundle (besides as an imported
package)?
cheers
Lorenzo
>>> Hi,
>>> ~Christian
> repositories...
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #873450 is a reply to message #873004] Fri, 18 May 2012 05:03 Go to previous messageGo to next message
Hi Lorenzo,
I think we fixed an issue in the unit test generator fragment that added
the package import for org.harmcrest by accident. Only
org.harmcrest.core is requrired (or the other way round - anyway, only
one of both imports was valid where the other one cause issues). Could
you please try with the latest nightlies?
Sebastian
Am 17.05.12 11:41, schrieb Lorenzo Bettini:
> Hi
> <repository>
> <id>orbit</id>
> <layout>p2</layout>
> </repository>
> Require-Bundle: ...
> org.junit4,
> org.apache.log4j,
> org.hamcrest,
> org.hamcrest.core
> package)?
> cheers
> Lorenzo
>>>> Hi,
>>>> ~Christian
>> repositories...
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #874238 is a reply to message #873450] Sun, 20 May 2012 04:32 Go to previous messageGo to next message
On 05/18/2012 11:03 AM, Sebastian Zarnekow wrote:
> Hi Lorenzo,
Hi Sebastian
I tried
http://download.eclipse.org/modeling/tmf/xtext/updates/composite/latest/
i.e., 2.3.0.v201205191342 and I still get this MANIFEST.MF for the test
plugin, which shows the same problem (which, again, can be fixed by
adding org.hamcrest as a Require-Bundle and not just Import-Package):
Require-Bundle: org.xtext.example.mydsl,
org.xtext.example.mydsl.ui,
org.junit4,
org.apache.log4j,
org.hamcrest,
org.hamcrest.core
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #874626 is a reply to message #874238] Mon, 21 May 2012 05:18 Go to previous messageGo to next message
Lorenzo Bettini wrote on Sun, 20 May 2012 10:32
I tried
Hi Lorenzo,
this bug was fixed on 15.05, so your version v20120519 contains the fix already, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=379521
I've tried both wizard and generator with the most recent version 2.3.0.v201205201426 and all works as expected. Only the org.hamcrest.core package import is generated.
Dennis.
P.S.: You can't import org.hamcrest package because it's hidden/protected, see the bug report for more information.
[Updated on: Mon, 21 May 2012 05:19] by Moderator
Re: [Xtext 2.3.0M7] org.hamcrest in the test plugin [message #874777 is a reply to message #874626] Mon, 21 May 2012 10:23 Go to previous message
>> I tried
>> test plugin, which shows the same problem (which, again, can be fixed
>> by adding org.hamcrest as a Require-Bundle and not just Import-Package):
> Hi Lorenzo,
> Best regards,
> Dennis.
Hi Dennis
sorry I hadn't realized my workspace was using a target platform based
on xtext 2.3.0M7 so I wasn't actually using the latest generator :)
with the current 2.3.0.v201205210926 the generated MANIFEST.MF for the
test plugin is
org.junit4,
org.apache.log4j,
org.hamcrest.core
which keeps Tycho happy :)
thanks
Lorenzo
Previous Topic:higher-level access to model
Next Topic:First steps with 2.3
Current Time: Fri Jul 25 02:46:26 EDT 2025
Powered by FUDForum. Page generated in 0.41273 seconds
