Home » Eclipse Projects » Eclipse 4 » How to set/modify the style of the application window
How to set/modify the style of the application window [message #871237] Fri, 11 May 2012 10:36 Go to next message
I need to set a specific style to the main application window.
In RCP 3.X this setting was done in the preWindowOpen() method of the workbench window advisor, before the application window was created.
public void preWindowOpen() {
IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
configurer.setInitialSize(new Point(1024, 768-1));
--------> configurer.setShellStyle(0);
Is there any way to do the same in RCP 4?
In the application model I have defined a Window not a TrimmedWindow.
fausto
Re: How to set/modify the style of the application window [message #871242 is a reply to message #871237] Fri, 11 May 2012 11:20 Go to previous messageGo to next message
The only solution I can think of is to write your own renderer.
Can you file a bug so that we allow this to be configured through CSS.
All we would need to do is to make the WBWRenderer access the CSSEngine
to query the shell-style value.
Tom
Am 11.05.12 16:36, schrieb Fausto Telia:
> Thanks
> fausto
Re: How to set/modify the style of the application window [message #871281 is a reply to message #871242] Fri, 11 May 2012 14:31 Go to previous messageGo to next message
We can't get shell styles from CSS as we don't have a widget to look up against.
A workable approach would be to have the renderer look for SWT.XXX-style tags in the MWindow's tags.
Re: How to set/modify the style of the application window [message #871527 is a reply to message #871281] Mon, 14 May 2012 06:34 Go to previous messageGo to next message
As suggested, I have submitted bug 379396.
thanks
fausto
Re: How to set/modify the style of the application window [message #996977 is a reply to message #871527] Thu, 03 January 2013 05:28 Go to previous message
Cant we create tags and use them on application window
Previous Topic:Decorating tab icons
Next Topic:Eclipse 4 user interface testing with SWTBot
Current Time: Wed Jul 23 19:05:19 EDT 2025
Powered by FUDForum. Page generated in 0.05592 seconds
