Avoid aggregation for y-axis [message #871218] |
Fri, 11 May 2012 09:27  |
Hi everyone!
First of all I like BIRT and I managed to create some really nice reports for my tests.
Now I want to create a report for my test summary, I have different test runs for my test cases (x-axis). An equal test case in different test runs can be identified by its name. Because I want to compare the result of each test case I want to group them by their name. Every test run has a different date (y-axis).
I use optional y grouping (Test Succeful, Test Failed).
When I am using grouping for the x-axis it isn´t possible anymore to set "none" for aggregation of the y axis. I also cannot change x and y because y I need x for grouping the Test Case Names.
I want to see the test result for every test case for every run. Any ideas?
FUDForum. Page generated in 0.03891 seconds
