Home » Eclipse Projects » Rich Client Platform (RCP) » Product Export Wizard based on Features
Product Export Wizard based on Features [message #871147] Fri, 11 May 2012 03:15 Go to next message
Hi all,
I have a product Myproduct.product which runs fine and when I export using export wizard it exports fine even for multiple platforms.
To include p2 update I have another product which is based on features and in this product I've select the Myproduct.product as a dependency. It works fine when running, and when exporting for the current platform (Ubuntu 64bit). When I select multiple platforms linux(gtk/X86,gtk/x86_64) then it is giving error
 Cannot complete the install because one or more required items could not be found.
 Software being installed: MyProduct 1.0.0.201205111232 (....myProduct 1.0.0.201205111232)
 Missing requirement: MyProduct Update 1.0.0.201205111232 (......p2.feature.feature.group 1.0.0.201205111232) requires 'org.eclipse.core.filesystem.linux.x86_64 [1.2.0.v20110423-0524]' but it could not be found
 Cannot satisfy dependency:
What is the way to export to multiple platforms when using product based on features.
Sajja
Re: Product Export Wizard based on Features [message #871154 is a reply to message #871147] Fri, 11 May 2012 03:29 Go to previous messageGo to next message
After removing the particular versions (....linux.x86_64) from the plugins it works fine.
[Updated on: Fri, 11 May 2012 03:29] by Moderator
Re: Product Export Wizard based on Features [message #871185 is a reply to message #871147] Fri, 11 May 2012 06:32 Go to previous message
I suppose to double check whether delta pack (platform-specific)
plug-ins are part of your active target platform.
Cheers
Libor
On 05/11/2012 09:15 AM, sajja Phani wrote:
> Hi all,
> be found.
> 1.0.0.201205111232)
> could not be found
> on features.
> Thanks
> Sajja
Previous Topic:Eclipse 3.x vrs. Eclipse 4.x
Next Topic:Command not defined
Current Time: Thu Jul 24 21:50:41 EDT 2025
Powered by FUDForum. Page generated in 0.05344 seconds
