Home » Archived » Jubula » Can not select menu item of Eclipse SDK 4.2 M7
Can not select menu item of Eclipse SDK 4.2 M7 [message #871131] Fri, 11 May 2012 01:06 Go to next message
I found that select menu operation fails in eclipse 4.2M7.
I defined an AUT that starts eclipse SDK 4.2M7, then defined a simple test case that select the menu bar using IndexPath: 1/1/1, which will active the new project dialog.
This operation just failed as "Not Found". The same case runs fine on the eclipse 3.7.2 release.
I'm using the Jubula 1.2.0 release. Any ideas?
Re: Can not select menu item of Eclipse SDK 4.2 M7 [message #871139 is a reply to message #871131] Fri, 11 May 2012 02:41 Go to previous messageGo to next message
this reminds me of this bug. It seems that you ran into the same issue.
Oliver
Re: Can not select menu item of Eclipse SDK 4.2 M7 [message #871158 is a reply to message #871131] Fri, 11 May 2012 03:59 Go to previous message
When you look at the bug Oliver mentioned you'll notice that it depends on a SWT bug. The fix for that bug is scheduled for Juno SR1 (due in September). Until then menus with 4.2 will not be testable.
Previous Topic:Need to confirm completion of successful process
Next Topic:Store window title
Current Time: Sun Jul 27 10:07:55 EDT 2025
Powered by FUDForum. Page generated in 0.03865 seconds
